A small front rack I built. I'd previously modified a rear rack to work on the front of my Fargo, but found that having weight so far forward made steering slow.
So I set about making this. My goals were to make it so that the weight would be kept as low as possible and as close to the steering centerline (i.e. steerer tube) as possible.
The rack itself, and the stem & handlebar attachments I built several months ago.
In my typical overbuilding modus operandi, I decided a while ago that there was a weak spot where the rack attaches to the fork crown; I finally got around to making the lower support struts today.
Obviously not ultralight, and my brazing skills leave much to be desired, but I have no doubt that it'll hold up just fine.
Still needs paint.
