  Topic Name: DIY water bladder on: March 26, 2018, 11:24:45 PM
Enjoying the View
« on: March 26, 2018, 11:24:45 PM »
Has anyone ever made their own water bladder to custom fit their frame bag?  I can’t help but think this would be a good idea. For me in particular my frame bag is not all that large and being on a full suspension frame the shape is odd enough to make it hard to get a stock bladder to fit. It got me thinking that since the bag itself was custom made to fit why not a bladder to match?
If anyone has, what material and parts did you use? I’ve got plenty of old bladders laying around. I could probably use pats from them if I could track down the same material to make the bladder. I’m sure there would be some trial and error. I’ve started looking at a seamer / welder to join the materials together.
Fully Packed Adventure Ministries www.fullypacked.org/fpamdenver
  Topic Name: DIY water bladder Reply #1 on: March 28, 2018, 06:27:16 AM
« Reply #1 on: March 28, 2018, 06:27:16 AM »
I have thought about doing this a couple of times, but I found a workaround that has kept me pretty happy. The Platypus bladder is longer, thinner, and doesn't have that huge port you need to cram into your bag. If you leave it a little under filled, it is surprisingly flexible and can fit into just about any space.
  Topic Name: DIY water bladder Reply #2 on: March 28, 2018, 12:41:10 PM
Enjoying the View
« Reply #2 on: March 28, 2018, 12:41:10 PM »
I do need to just pick one of those up or even the Camelbak longneck bladders and see how it fits.
  Topic Name: DIY water bladder Reply #3 on: April 01, 2018, 08:36:43 PM
mtntraveler
« Reply #3 on: April 01, 2018, 08:36:43 PM »
Enjoying the view
 if you get around to making a custom bladder, let the forum know as I've seen the topic here a few times.  I would also like a custom fitted bladder to my frame bag, that would be super.
  Topic Name: DIY water bladder Reply #4 on: April 02, 2018, 04:38:13 AM
« Reply #4 on: April 02, 2018, 04:38:13 AM »
I think the hardest thing would be sourcing food grade materials. Otherwise, you could use pack raft supplies and construction.
  Topic Name: DIY water bladder Reply #5 on: June 26, 2018, 07:34:44 PM
ForestyForest
« Reply #5 on: June 26, 2018, 07:34:44 PM »
I designed an insulated pouch to hold a 3L reservoir on the handlebars.  It has a front pocket for snacks, and a rear pocket that fits a smartphone.  The current design requires an Ortlieb Handlebar Pack to fit correctly, but it would be nice to make it universal eventually.  I offer these for sale on Etsy if anyone is interested.
  Topic Name: DIY water bladder Reply #6 on: June 26, 2019, 04:42:06 PM
geekonabike
« Reply #6 on: June 26, 2019, 04:42:06 PM »
I once tapped a 2 gal bag into a triangular shape, it lasted a couple of years before springing a leak. now I just add a second caped 3l platypus bag, partially filled & get the same amount of storage (smallish ft triangle). platypus bags are also good for springing leaks, but gorilla tape will usually get you through the trip.
