vermont
« on: February 24, 2018, 04:05:34 PM » |
I believe Foodsaver is a brand name but you get the point. I just "made" a dry bag with a food saver bag. It does hold water without leaks (thank goodness) but the roll top would not hold air. I then just put a piece of webbing through the roll top and strung it around the bottom. As long as you sew in the sealed edge, then it would be easy to make daisy chains or actually sew a strap on. The 8 inch wide bag made for a 14 inch diameter bag. I could not fit my Klymit sleeping bag folded over 4x but it did fit in when folded over 3x. So it would be perfect for a fork mounted bag or a dry bag in a frame bag. I thought I would share by idea... Lightweight, cheap, semi disposable.
