  Topic Name: Frame bag chain ring clearance necessary? on: January 08, 2015, 12:22:30 AM
Wilburforce
« on: January 08, 2015, 12:22:30 AM »
Hello there,
I was curious about chain ring clearance - I use an internal gear hub or SS so there's no front mech to worry about.
Nor would it be a problem for the velcro as I will be using a webbing ladder with One Wrap velcro wherever I deemed it appropriate - like this - https://www.alpkit.com/products/possum
But as it's a large traditional road frame - would it be a problem with a 2.5-3" or 6-7cm wide frame bag to go to the bottom of the triangle..?
Obviously at those widths the bag doesn't overlap the BB shell. But without actually stuffing things in a completed bag I can't tell whether I should be prudent and end it a cm above the chain or just go to the bottom...?
Thus is there generally a consensus on chain ring clearance - likewise am I just inviting muck or water to congregate and seep into the bag if I go right into the corner?
Thanks
  Topic Name: Frame bag chain ring clearance necessary? Reply #1 on: January 13, 2015, 10:51:05 PM
Smo
« Reply #1 on: January 13, 2015, 10:51:05 PM »
An easy solution to the clearance issue is just to taper the bag near the bottom.  Just make the seat tube and down tube panels get a little skinnier for the bottom few inches. That's what I did on the framebag in my avatar, which I wanted to have fill the frame completely for aesthetic reasons.  It was a 2.5" wide bag in general, and i tapered down to 2" - it's just enough to clear my derailleur and works great.
