Topic Name: Frame bag reinforcement and questions
on: April 07, 2014, 06:49:37 AM
Bob Loblaw
« on: April 07, 2014, 06:49:37 AM » |
I keep hearing how there is much more abrasion in a frame bag than you would think.Would it be worthwhile to use a heavier fabric on the surfaces that will see the most contact with the frame? (The surfaces with the yellow lines in the picture). Currently I was thinking about using xpac (VX-21) for most of the bag and something heavier like 1000 Denier Cordura for the high-wear areas. - Is this needlessly complicated?
- Is VX-07 better suited for this use or should I stick with VX-21?
Reply #1 on: April 07, 2014, 07:57:38 AM
paulmissoula
« Reply #1 on: April 07, 2014, 07:57:38 AM » |
I think many folks making bags are using ballistics or a heavier cordura nylon for the panels in touch with tubes. On the bags I make, I use VX21 on the main panels and 1000D Cordura for the panels that are in contact with the tubing. It's worked well for me.
Reply #2 on: April 07, 2014, 09:45:20 AM
Reply #3 on: April 08, 2014, 10:11:44 AM
Racingguy04
« Reply #3 on: April 08, 2014, 10:11:44 AM » |
I haven't put tons of miles on my frame bags, but I've just used vx-21, It might wear out someday, but I don't get out enough to make that happen or justify the extra expense/complication of using cordura for the frame parts.
Reply #4 on: April 09, 2014, 12:16:40 AM
« Reply #4 on: April 09, 2014, 12:16:40 AM » |
In my experience...
For a partial frame pack that has a bottom section not in contact with a down tube you can get away with using a lighter material, top tube sections the same. I only use heavier/reinforced or padded sections where the pack sits against the frame on seat and down tubes only.
Where padded sections, reinforcement and heavier more abrasion resistant materials are particularly useful are for full frame packs with the bottom and back sections that sit against the down tube and seat tube. This is where you'll get the highest abrasion as your gear, more than likely heavier stuff, works its way down and settles from road/trail vibration, it begins rubbing, knocking, and you risk wearing through your frame bag or worse your frame.
My last full frame bag used a heavy VX as the outer, was padded with ccf and used VX07 for the inside. A 2000km dirt road ride through Chile the frame bag was fine although there are a few spots on my down tube and seat tube wore through the paint and to the steel. A carbon frame for that particular trip would've likely been junked.
Reply #5 on: April 09, 2014, 07:27:00 AM
Bob Loblaw
« Reply #5 on: April 09, 2014, 07:27:00 AM » |
Thanks for the replies. My order from rockywoods should be here today and I'll give this a go this weekend.
Reply #6 on: April 14, 2014, 06:16:05 AM
roadpacker
« Reply #6 on: April 14, 2014, 06:16:05 AM » |
I am going to experiment with 1.5" webbing on certain wear spots on mine; namely where the old bolts for the bottle cages were, and where my frame pump connecting gizmo is.
Reply #7 on: April 21, 2014, 09:10:23 AM
wunnspeed
« Reply #7 on: April 21, 2014, 09:10:23 AM » |
I'm with Paul... my bags are generally X21 like him and 1000D Cordura on the tube side. One other thing I do is to add some vinyl reinforced poly fabric at the bottle mount and cable stop locations. It works well for me thus far and no one has ever come back claiming their bags have worn through.
