Topic Name: Gas Tank Bag w/ Top of tube cable routing?
on: February 12, 2013, 08:00:22 PM
Danish
« on: February 12, 2013, 08:00:22 PM » |
I have been thinking about design problems and potential solutions for a gas tank style bag and it occurred to me that the cable routing on my bike runs along the top of the top-tube. It seems to me that the bag would rub on and possibly affect cable action. Has anyone come up with a nifty spacer solution or is this a problem that I don't need to worry about?
Reply #1 on: February 14, 2013, 01:58:19 AM
jmpg
« Reply #1 on: February 14, 2013, 01:58:19 AM » |
Full length cable housing will fix the the issue of cable rub.
Reply #2 on: February 19, 2013, 08:32:39 AM
ocary
« Reply #2 on: February 19, 2013, 08:32:39 AM » |
I solved this problem on my CX bike by electrical taping a couple finger sized scraps of wood to the top tub parallel to the cables. This created a channel for the cables and enough of a platform for the top-tube bag that the cables move fine. It is ugly, but it works. Full length housing would be a more elegant way and I keep saying I'm going to take off the wood and put on housing; it has been 3 years.
Reply #3 on: February 22, 2013, 12:18:07 AM
jp3d
Jesse Palmer
« Reply #3 on: February 22, 2013, 12:18:07 AM » |
I found it to be a non-issue. In my case the bags are mostly held tight against the cable stops, cable housing, head/seat tube. The bag-cable contact doesn't add any noticeable friction.
party till you björk
Reply #4 on: February 22, 2013, 06:29:01 AM
riverfever
« Reply #4 on: February 22, 2013, 06:29:01 AM » |
On my Orbea Alma this was a big issue for the rear derailleur. I ended up using a section of brake cable housing that was cut to the length of the open section of derailleur cable (probably 14"?). This was clean. I opted for brake cable housing vs. derailleur housing because it created less friction for that area than a piece of SIS housing would so dirt getting in there was less of an issue.
Reply #5 on: February 22, 2013, 12:58:37 PM
« Reply #5 on: February 22, 2013, 12:58:37 PM » |
My dad has this issue on his CX bike. He taped a washing machine drain hose mounting bracket (it is basically a pipe elbow split in half) to his frame where the gas tank sits. A couple ounces, but keeps the cables happy; you just velcro the bag on over the bracket as normal.
Reply #6 on: March 06, 2013, 05:05:15 PM
tehschkott
« Reply #6 on: March 06, 2013, 05:05:15 PM » |
Seriously this is a non-issue. Can't feel it and doesn't impact braking, can't feel it and doesn't impact shifting.
Reply #7 on: March 07, 2013, 10:38:09 AM
riverfever
« Reply #7 on: March 07, 2013, 10:38:09 AM » |
Was a huge issue on the Alma.
Reply #8 on: March 07, 2013, 10:57:01 AM
tehschkott
« Reply #8 on: March 07, 2013, 10:57:01 AM » |
What do you carry in there? Buckles?
