  Topic Name: Light(er) Weight Pannier System on: November 26, 2013, 04:03:43 AM
dfoginc
« on: November 26, 2013, 04:03:43 AM »
Here is an idea for a light weight pannier system. It is basically a sling that a dry bag slides in to. I know it's not a normal bike packing system but we are planning a 6-8 month trip, primarily on pavement but with some trail riding. We'll be carrying a lot of gear, about 25-30 LB per bike plus food and water. With that much gear, I'd like to keep the weight as low on the bike as possible.
The sling weighs 160 grams and the 25 liter dry bag weighs 190 grams.  The rack is a Topeak Explorer and weighs 625 grams.
The blue fabric is from some heavy duty rain pants and the yellow material is from a school crossing vest, both purchased from a thrift shop. The webbing and buckles are .75" wide except the center belt is 1" wide. The plastic tubing shown is slid into a pocket where the blue and yellow fabric meet. It allows the blue fabric to be stretched tight and it helps to keep the dry bag flat when the middle webbing is tightened. There is a loop of .5" webbing that goes around the tube end at the bottom of the rack. In line with this loop is a buck that connects the sling to the top of the rack. This is the main attachment to the bike. There are also velcro in the top corners that hold the fabric in place but carry no weight. The blue material was used near the wheel because it will be easier to clean, the yellow material was used on the outside for reduced weight. The silly pattern that was on the vest is just a bonus.  Wink
The webbing is sewn along the edges and the ends buckle together to form an entire loop, effectively hanging the dry bag from the rack.
It only takes 30 seconds to attach the sling to the bike and another 30 seconds to install or remove the dry bag. To remove the dry bag, You unsnap the middle buckle and unsnap one top  corner buckle. My plan is to leave the sling on the bike at night so I'll only need to pull out the dry bag.
I am considering making an even lighter version but would like to do quite a bit of riding with it first to see what improvements are needed. For the improved version, I'd like to use a strong and light material for the sling so that it carries the weight of the dry bag and would not need to be reinforced with webbing. I'd be pleased if I can get the sling down to 100 grams. My current dry bags weigh 190 grams each. Ortielb, Exped, and others make similar sized bags that only weigh 80-100 grams.  I'd like to go to a rackless system but I also have a desire to carry the weight low so not sure how to accomplish both.
« Last Edit: November 26, 2013, 04:40:37 AM by dfoginc » Logged
  Topic Name: Light(er) Weight Pannier System Reply #1 on: November 26, 2013, 04:00:43 PM
Smo
« Reply #1 on: November 26, 2013, 04:00:43 PM »
Nice!  I toyed with the idea of using velcro for the top straps on my own, very similar panniers (http://www.bikepacking.net/forum/index.php/topic,6264.0.html).  Haven't tried it yet, but I think I'm going to now; your system looks so much cleaner than mine does.  Mine has an experimental, inconvenient buckle system up top.
Do you have any clever ideas for how to secure the loose ends of the straps?  When mine are fully collapsed, there's quite a bit of slack left, and i haven't come up with a nice solution yet.
My first try at bags were really similar to yours, but I decided to make dedicated bags that strap down instead of a sling.  Putting a stuff sack into the pannier and getting it all strapped up was just a bit of a pain, and I usually use plastic liners (read: trash bags) instead of dry bags anyway, so there was really no incentive for me to keep the sling design.
Let me know how the buckle tie-downs work out; so far, mine seem to be ok, but I think that with heavy abuse the webbing might slip.  I haven't taken them loaded on a trail yet.  I have some 3/4" cam buckles on order from rockywoods and I'll report in my thread on how those work out when I get them.  They're pretty cheap:  http://www.rockywoods.com/Hardware-Zippers/Buckle-Hardware/3-4-Cam-Buckle-Black
EDIT: Plastic cam buckles, NOT recommended.  More slippage than regular slide release buckles.  Right now I'm testing out the "SIDE RELEASE LATCH CAM BUCKLE" from Quest.  So far, so good:  http://www.questoutfitters.com/plastic.htm#Acetal Fasteners
« Last Edit: April 04, 2014, 09:24:36 PM by Smo » Logged
  Topic Name: Light(er) Weight Pannier System Reply #2 on: December 05, 2013, 01:44:58 AM
« Reply #2 on: December 05, 2013, 01:44:58 AM »
That looks REALLY good. Really good. Nice work. With such an emphasis on seatbags - they aren't for every application - where you genuinely need to carry a heap of stuff (bulky).
  Topic Name: Light(er) Weight Pannier System Reply #3 on: December 06, 2013, 05:19:23 AM
dfoginc
« Reply #3 on: December 06, 2013, 05:19:23 AM »
Area53,
Thanks, my wife is really good with her sewing machine.
I plan to carry a dry bag on one side and a backpack on the other side. Yes, it's a lot of gear but we'll be living on the road for half year so are splurging on a few items. Since we'll be living primarily in a tent and camping most nights, I'm planning to bring a huge tent, a Marmot Limelight 3. I expect it will wear out before the trip is over and will reevaluate the shelter then.
In the photo below, I have the backpack pretty full but on the trip I'm planning to keep it nearly empty so I can use it as a day pack for hiking and grocery shopping. I seem to have more trouble with neck pain when I bike with a backpack so will try and avoid that.
Smo,
My strap ends aren't long enough to be a problem. What little extra strap there is can be tucked in between the bag and the sling.
My next project will be to make a handlebar sling with detachable handlebar bag. I've gathered the parts for the sling but the part I'm still working out is a design of a bag that can be easily unsnapped from the sling and carried as a hip belt, messenger bag, backpack or ? I'm wanting something very small, just big enough to hold my wallet, passport, sunglasses, snacks, etc and that I'll unsnap from the bike and wear into shops or other times that I leave my bike. Either something I can buy or make. Any suggestions for this would be welcome.
  Topic Name: Light(er) Weight Pannier System Reply #4 on: February 05, 2014, 04:40:02 AM
roadpacker
« Reply #4 on: February 05, 2014, 04:40:02 AM »
Very cool, I like that a lot. Perfect for bike-then-hike missions.
Goal: 330 in 36 hrs
  Topic Name: Light(er) Weight Pannier System Reply #5 on: February 25, 2014, 04:21:06 AM
gnpais
« Reply #5 on: February 25, 2014, 04:21:06 AM »
They're great! I get to see them live and they look even cooler! ;o)
Way to go!
See ya
GPais
  Topic Name: Light(er) Weight Pannier System Reply #6 on: March 11, 2014, 04:50:29 PM
Irish Tsunami
« Reply #6 on: March 11, 2014, 04:50:29 PM »
These look great, how are you attaching the bottom to the rack?  Can you provide a picture of it laid out flat with the face up?  I now have a spring project.
