  Topic Name: Made my first Handlebar Harness... on: May 04, 2015, 06:00:37 AM
werkinit
« on: May 04, 2015, 06:00:37 AM »
I managed to build myself a pretty awesome handlebar bag harness out of some scrap plastic from work, a few clips, 1" strap and a bit of velcro. I Also scored a small frame bag on clearance from M.E.C. , (the REI of Canada) that barely fits into my weird shaped bike triangle.
 I don't have a compression sack or anything like that so I just put the hammock bag in the harness for now. In the frame bag I just managed to fit my pop can stove and pot kit.
I also had in my backpack an Aeropress coffee maker, a new purchase I wanted to try out, out of doors.
I loaded the bike with gear and headed out for a day of trail riding in one of the roughest trail systems in Ontario. I figured being pummeled by constant rock riding would be a good test for the straps on the harness.The harness holding the 4lb hammock kit worked perfectly. No movement at all. I could even jump with it with no movement or clip failure. I imagine the shape would be more rounded if I used a cylindrical compression sack. I'm fine with how it is though.
  Topic Name: Made my first Handlebar Harness... Reply #1 on: May 06, 2015, 02:19:49 PM
marpilli
« Reply #1 on: May 06, 2015, 02:19:49 PM »
Nice! I'd be interested in some detail shots of the handlebar harness when you have the time.  Smiley
  Topic Name: Made my first Handlebar Harness... Reply #2 on: May 11, 2015, 10:56:41 AM
Marna
Riding at Home
« Reply #2 on: May 11, 2015, 10:56:41 AM »
Nice.
Just ride your own bike and have fun!
  Topic Name: Made my first Handlebar Harness... Reply #3 on: May 12, 2015, 10:03:58 AM
werkinit
« Reply #3 on: May 12, 2015, 10:03:58 AM »
You asked for it!
So first I scoured this site as well as rest of the internet for ideas and settled on a design that involves strapes being webbed through a harness and around the handlebars as there was now sewing. This way I could use the materials I have lying around the shop.
First step was to make sure it would work. I made a basic mock up out of cardboard and simulated bars and a bag with materials I had close at hand.
*EDIT*: Forgot to post a picture of the first lifesize mock up which I used to map out the strap hole spacings and general shape of the working mock up. It's below the black plastic picture and out of sequence:(
Once I was convinced my ideas would work I cut up another rough mock up with the actual material I would be using and experimented with scrap stapping of various widths and wrap configurations. I used this mock up to strap to my bars and try different stabalizing methods. The cuts in the centre were for running a strap through and around my headtube. I ended up running the straps under my forks and up to the front which works amazingly. The center cut holes were still usefull as I use them for the 2" hoizontal strap which is I suspect more of a safety feature than anything else . It keeps the bag inside the harness from moving side to side and helps take off some stress from the buckles. It may be overkill but could come in handy in ways I haven't thought of yet so it stays.
« Last Edit: May 12, 2015, 10:26:38 AM by werkinit » Logged
  Topic Name: Made my first Handlebar Harness... Reply #4 on: May 14, 2015, 10:56:15 AM
werkinit
« Reply #4 on: May 14, 2015, 10:56:15 AM »
Now the finish product.
Once I was happy with the strap details, I measured everything out and cut the slots properly
using a drill on the corners prevents the plastic from tearing.
I used dental floss for thread and I think put the clips the opposite way around than normal with the intention of
using tension to close them closed.
The velcro is a backup in case the clips slip and also keps the straps from flopping about.
  Topic Name: Made my first Handlebar Harness... Reply #5 on: May 14, 2015, 10:58:01 AM
werkinit
« Reply #5 on: May 14, 2015, 10:58:01 AM »
and
