  Topic Name: MYOG: Bivy on: February 07, 2012, 07:54:16 PM
JReeves
« on: February 07, 2012, 07:54:16 PM »
Well I finally made the plunge.  I spent the last few weeks kicking around ideas in my head, and browsing on here for some inspiration and .  I scored 3 yards of eVent fabric in the Gear Swap section of Backpackinglight.com and I knew exactly where I'd put it to use.  I'm racing in the Colorado Trail Race this year, and wanted a shelter with a compromise of simplicity, waterproofness, durability, and weight.  I wanted to avoid having to set up a tarp/tent, so this meant that the bivy I used needed to be completely waterproof, not just water resistant.  I was willing to sacrifice a few ounce of extra weight, even over a ultra-light bivy and tarp combo, as this would make for an easier setup after 14 hours straight on the bike.  I also made it a little larger than it needed to be, this gives me room for my Neoair pad, some extra room to store clothing if it gets nasty out, and also just for some wiggle room.
Top fabric is eVent, bottom is 1.9oz PU Coated Nylon(again, a sacrifice of weight for strength).  It has tie out loops on both the body portion, and hood portion of the zipper, which is a YKK #3 Water Resistant.  Also pretty proud of the matching stuff sack I made for it... hahaha
Ready for bed.
Matching stuff sack...
Under one pound...
Part 2, the nano-see-um window insert...
I finally finished her up a few days ago, and just now got all the pictures loaded up and hosted...  Here she is.  It came out better than I truly was hoping for.  I wanted something removable, as I don't often need the bug netting on my trips, but wanted the option.  The window insert is simple, and very effective.  And the best part, it's only 1oz...  It rolls up to about the size of a AA battery, so it's compact and easy to store in the bottom of the stuff sack for use if needed.  I put small grossgrain loops at each end to make removal easy from the inside.  To crawl in and out it's as simple as undoing one edge of the velcro and wiggling your way out.  It puts my total bivy weight with stuff sack, and 3' of elastic tie-out cord at 16.05oz.  All in all, I'm very pleased with my first attempt!  Can't wait to get out and get it dirty!
Insert laid out:
Laid over the bivy for size refernce:
Close up of the velcro that is sewn just inside the zipper portion of the bivy.  This remains on the bivy at all times, and is then mated with the velcro strip that borders the entire mesh window.
Another close up.  This one showing how nicely the velcro seals at the edge of the border.  It'll definitely keep out the creepy crawlies...
This is just demonstrating the location of the upper tie-out point on the hood portion.  Gives me tons of ventilation and great visibility.
And this is the same as the above one, but showing it with the bivy completely water-tight.
  Topic Name: MYOG: Bivy Reply #1 on: February 08, 2012, 09:21:21 AM
keeb
« Reply #1 on: February 08, 2012, 09:21:21 AM »
Look forward to an update on how well it deals with condensation in actual use.  I may have just found my next project.  thanks for posting this.
  Topic Name: MYOG: Bivy Reply #2 on: February 08, 2012, 09:51:02 AM
Ultra Magnus
« Reply #2 on: February 08, 2012, 09:51:02 AM »
I was following that thread on BPL but didn't realize it was you...  It looks like it turned out fantastic, and I'm really interested in hearing how well it worked in actual use, especially when sleeping in rain w/o a tarp.  That takes some guts imo.  Did you seam seal it?  (sorry if you mentioned it, I can be reading comprehension-ally challenged sometimes).
BM
  Topic Name: MYOG: Bivy Reply #3 on: February 10, 2012, 01:48:08 AM
« Reply #3 on: February 10, 2012, 01:48:08 AM »
Awesome! this is very similar to what I have in mind for my ultimate quick set up shelter; eVent, removable netting, spacious enough for gear, you've got it covered....now to keep an eye out for more of that elusive eVent. Nice detail photos. Great Job J.
  Topic Name: MYOG: Bivy Reply #4 on: February 10, 2012, 07:02:23 PM
Funrover
« Reply #4 on: February 10, 2012, 07:02:23 PM »
How has this help up? I like the simplicity!
  Topic Name: MYOG: Bivy Reply #5 on: April 18, 2012, 02:21:04 PM
ruthslp
« Reply #5 on: April 18, 2012, 02:21:04 PM »
yeah this looks good. i am thinking of starting to make one as well. interested in how much you had condensation issues?
i have condensation in everything i have tried to sleep in so far regarding bivy materials (anything with a waterproof/breathability rating).....and one layer tents as well. I wake up soaked and cold no matter what....
  Topic Name: MYOG: Bivy Reply #6 on: April 18, 2012, 06:13:53 PM
JReeves
« Reply #6 on: April 18, 2012, 06:13:53 PM »
I honestly haven't gotten out to use it yet...  My titanium bikepacking rig that I ordered months ago is just now getting finished up...  I have a shakedown run planned for mid May to test out everything I'll be using on the CTR.
I'm hoping the eVent fabric will be as great as I've read it is!!!
I'll definitely keep you posted on everything and an update with it's performance.
  Topic Name: MYOG: Bivy Reply #7 on: May 25, 2012, 07:09:56 PM
JReeves
« Reply #7 on: May 25, 2012, 07:09:56 PM »
Well this weekend will be the test... I'm heading out on a 3 day trip in the Toiyabe Range here in the middle of Nevada.  Elevation will be 7,500-11,000 feet, and the weather now is calling for a cold and wet first day out.  I'm also packing my ID Siltarp1 to give me a little shelter should it be coming down heavy.  I'll be sure to take some pictures and update you guys with a performance report!
  Topic Name: MYOG: Bivy Reply #8 on: May 30, 2012, 08:00:21 PM
mbeardsl
« Reply #8 on: May 30, 2012, 08:00:21 PM »
How did it perform?
  Topic Name: MYOG: Bivy Reply #9 on: May 31, 2012, 09:48:02 AM
JReeves
« Reply #9 on: May 31, 2012, 09:48:02 AM »
Well...  The trip got sidetracked right off the bat.  As we approached the mountain range that we'd be riding on top of, it was apparent that a change of plans was needed.  There was about a foot of fresh snow, and it was still coming down lightly.  So we drove all the way around the range down to the south end of the range and camped at the truck at a lower elevation spot was pretty dry.  The next morning we headed out on what proved to be an adventure.  The first 9 miles were hike-a-bike over your head up 3,000 feet in the snow, on what at one point was a trail...  There was some riding mixed in, including a muddy 20 stretch to end the day still about 40 miles from camp.  Obviously we had everything we needed to get through the night anywhere we liked, so we pulled off the dirt road after about 12 hours on the move.  Set up camp in a sandy wash.  The sky was clear that night, and not much of a wind(at least when we went to bed, got windy later) so I didn't even bother rolling out the bivy...  I did get to test my Western Mountaineering Summerlite bag though, and slept great every night.  So, at this point, all I can say is that it packs well... hahaha.  Going to do a overnighter next weekend and will be sure to get at least one night in it to test it out...
  Topic Name: MYOG: Bivy Reply #10 on: June 11, 2012, 06:16:16 AM
mosibiker
« Reply #10 on: June 11, 2012, 06:16:16 AM »
Any update on a trial run?
  Topic Name: MYOG: Bivy Reply #11 on: June 13, 2012, 05:22:15 PM
JReeves
« Reply #11 on: June 13, 2012, 05:22:15 PM »
So far so good!  Granted, I haven't gotten any precipitation yet while I've been in it.  It definitely is warmer sleeping in the bivy compared to without, which is nice, in that it will add a few degrees to my bag rating.  Used it this past weekend for an overnight trip up to Downieville.  It got down to the low 40's and I had no condensation inside, so that's promising.  I'm thinking I'm going to take it outside the next rain storm we get and crawl inside and see how it holds up...
  Topic Name: MYOG: Bivy Reply #12 on: June 20, 2012, 10:48:08 AM
juanesunpescado
« Reply #12 on: June 20, 2012, 10:48:08 AM »
I am currently inquiring with GE as to whether eVent is oxygen and carbon dioxide permeable. Many fabrics which are water vapor permeable are not permeable to O2 or CO2. It appears that your design is capable of sealing tightly. I would recommend leaving adequate ventilation unless you already know about the permeability. Excess CO2 causes shortness of breath which generally awakens a sleeping person. However there has been one documented case where a person suffocated in a sealed up bivy. They had been drinking which apparently suppressed the normal waking response.
  Topic Name: MYOG: Bivy Reply #13 on: August 01, 2012, 04:15:52 PM
juanesunpescado
« Reply #13 on: August 01, 2012, 04:15:52 PM »
in case you are wondering. GE claims eVent is both O2 and CO2 permeable.
