Topic Name: Need help making downtube bag.
on: February 02, 2017, 07:42:30 AM
werkinit
« on: February 02, 2017, 07:42:30 AM » |
Hello D.I.Yr's
I would like to work out and make a Down tube bag of some sort and need some inspiration. Anyone successfully accomplish this task?
Any and all pictures or comments welcome. Thanks.
Reply #1 on: February 02, 2017, 08:57:21 AM
werkinit
« Reply #1 on: February 02, 2017, 08:57:21 AM » |
Reply #2 on: February 02, 2017, 09:32:31 AM
« Reply #2 on: February 02, 2017, 09:32:31 AM » |
Do you mean a bag that hangs under the down tube or under the top tube?
Reply #3 on: February 02, 2017, 04:35:35 PM
bikelite
« Reply #3 on: February 02, 2017, 04:35:35 PM » |
It's either a top tube bag or frame bag, partial or uge.
Reply #4 on: February 03, 2017, 02:25:48 AM
« Reply #4 on: February 03, 2017, 02:25:48 AM » |
I make all of my own frame bags. I use a vinyl strip along the bottom to hold it to the water bottle bosses. the velcro on the ends and the top rally hold it in place. ![](http://bakerjw.org/IMG_20170114_172301903.jpg)
Reply #5 on: February 03, 2017, 09:01:08 AM
werkinit
« Reply #5 on: February 03, 2017, 09:01:08 AM » |
« Last Edit: February 03, 2017, 09:24:44 AM by werkinit »
Reply #6 on: February 03, 2017, 09:08:53 AM
« Reply #6 on: February 03, 2017, 09:08:53 AM » |
The same technique can be used. Attaching it to the down tube using the water bottle bosses would give it a lot more stability. Perhaps I'll throw something together and see how it rides. Not sure what I'd put in it though. That's an area that gets exposed to a lot of water and mud. Tent poles perhaps.
« Last Edit: February 03, 2017, 09:15:41 AM by bakerjw »
Reply #7 on: February 03, 2017, 12:38:12 PM
werkinit
« Reply #7 on: February 03, 2017, 12:38:12 PM » |
Interested in the results of your experiment.
Reply #8 on: February 04, 2017, 08:56:17 AM
vermont
« Reply #8 on: February 04, 2017, 08:56:17 AM » |
What are you hoping to put in it? It seems to be a pretty basic tube with a zipper and velcro attachments. If you really want it to stick go with three pieces of velcro. The middle one gets sandwiched between the outer two.
Reply #9 on: February 04, 2017, 09:49:22 AM
« Reply #9 on: February 04, 2017, 09:49:22 AM » |
Jefe's CTR set up from a couple years ago used one of his own homemade bags down there... skip to 12:45 if you don't want to watch the whole thing. https://www.youtube.com/watch?v=F-zmTSSWot4
Reply #10 on: February 19, 2017, 07:46:13 AM
Reply #11 on: February 22, 2017, 10:00:07 AM
werkinit
« Reply #11 on: February 22, 2017, 10:00:07 AM » |
This should do. http://www.farawayvisions.com/diy-dry-bag/I just have to stitch down tube straps across it. maybe an old piece of inner tube where the down tube touches the bag. if I can sew through it:)
