  Topic Name: Sleeping pads? on: November 01, 2011, 04:45:38 AM
orion_134
« on: November 01, 2011, 04:45:38 AM »
I'm looking for some advice on a sleeping pad for >30* in a hammock.  I remember reading about using a half-length foam pad under a full-length truck reflective visor, but I can't find any information again.  Any advice or suggestions?
Thanks,
Jesse
  Topic Name: Sleeping pads? Reply #1 on: November 02, 2011, 12:24:51 PM
JerryW
« Reply #1 on: November 02, 2011, 12:24:51 PM »
I can't really give any advise about pads, but have you thought about using an underquilt instead? They are much more comfortable and pack a lot smaller than a pad.
Check out Hammock Forums if you haven't already. Everything you could ever need to know about hammocks and hammock camping.
Jerry
  Topic Name: Sleeping pads? Reply #2 on: November 02, 2011, 01:28:36 PM
« Reply #2 on: November 02, 2011, 01:28:36 PM »
ive used the gossamer gear 1/4 pad, wide. been down to high 30s, with all my clothes on. not ideal, and it packs pretty large. wouldn't be able to easily carry it on the bike. the underquilt is a much better idea for cold weather hamock hanging.
  Topic Name: Sleeping pads? Reply #3 on: November 02, 2011, 01:59:45 PM
« Reply #3 on: November 02, 2011, 01:59:45 PM »
Thanks,
Jesse
If you are thinking about the weather you'll encounter on your November adventure.... consider a simple ground cloth and setting it up like a bivy. You'll be warmer that way. A sheet of Visqueen or Tyvec would work great to keep the bottom protected from water and poking holes... Since you're thinking of some sort of a pad anyway, this will work without issue.
  Topic Name: Sleeping pads? Reply #4 on: November 02, 2011, 03:07:03 PM
orion_134
« Reply #4 on: November 02, 2011, 03:07:03 PM »
November and beyond.  I like the quilt idea, but I thought the whole purpose was to get something that doesn't compress (see edit)?  Although I do like the idea of not having to deal with packing something semi-rigid like a pad/mat.
Rob - your hammock packs BIG!  If I get one, hopefully they offer it in non-gangly size:)
As for the Visqueen or Tyvec...you're speaking Greek, I'm off to the googlewebs.
EDIT - Looks like Home Depot sells it, but holy crap that's a lot of Tyvec to only need a little bit of it.
Oh, under quilts are something that hangs on the outside of the hammock.  Genius.  Now their price needs to come down.
« Last Edit: November 02, 2011, 03:58:28 PM by orion_134 » Logged
  Topic Name: Sleeping pads? Reply #5 on: November 02, 2011, 08:46:21 PM
« Reply #5 on: November 02, 2011, 08:46:21 PM »
I got by with a standard blue mat for a short time
http://www.rei.com/product/374059/standard-blue-foam-pad-long
I just rolled it out inside the hammock. Was glad to have it on a treeless night too.
then I got the Supershelter Insulation Systems
http://hennessyhammock.com/catalog/insulation/
It took a couple of days to get used to adjusting it, then it worked.
I have decided hammocks are best for shorter trips of a few days. I use a tent for longer trips.
  Topic Name: Sleeping pads? Reply #6 on: November 02, 2011, 09:05:25 PM
« Reply #6 on: November 02, 2011, 09:05:25 PM »
NLooks like Home Depot sells it, but holy crap that's a lot of Tyvec to only need a little bit of it.
I found my sheet of tyvek at a local home construction site. It's used as a vapor barrier/wrap for new houses. A bit of dumpster scouring and I had a piece that was more than large enough to make a ground cloth out of for a cost of $0.
  Topic Name: Sleeping pads? Reply #7 on: November 11, 2011, 04:39:19 PM
« Reply #7 on: November 11, 2011, 04:39:19 PM »
I know it's too late now but, there is a cat in Palm Bay that sells the stuff cut to size for hikers/campers. zpacks.com
