You can order heat sealable fabric from a number of sources if you want to skip the difficult sewing. Seattle Fabrics has several different weight fabrics and can provide an article from Sea Kayaker with the instructions.
http://www.seattlefabrics.com/nylons.html#heat sealable 30 Denier Ripstop
I've made some round bottom models for my own use from 400 denier ripstop pack cloth with a heavy urethane coating. Felled seams are overkill, just sew around the base perimeter two or three times and seam seal it with a silicon caulk/white gas(3 to 1) mix.
