1/19/2015 Update:
After about 1500 miles on my OneUp 40T cog, I had about 5/16" chain stretch and decided to install a new one (Sram 1070), whereupon I immediately got skipping on the 40T while mashing. Upon inquiry, OneUp customer service informed me that "1500 miles is an acceptable mileage for a cog to wear out" (the other cogs on the cassette have about 5x the mileage and no issues). They also advised me to replace the cog, so I ordered an new one... from Wolf Tooth. Upon further research, it appears that OneUp cogs are aluminum and Wolf Tooth are steel.
Edit: Wolf Tooth cogs may be aluminum also, can't tell for sure from their website.
2/9 Update:
I received and installed the 40T Wolfstooth. It is aluminum alloy but looks beefy compared to the OneUp and I got this pm from customer service:
"We have had 1 (yes 1) GC wear out since we started selling them. Now we know they WILL start to wear out at some point for people, but they are lasting far longer than 1500 miles.
Of note is that our teeth are 10% thicker than the brand that you had making the wear surface larger and he life significantly longer (lots of variables here so I don't want to quote
a % longer life). We can have this additional thickness, which by the way is also stiffer, because of how we create the shift gate teeth (relieved on the back side and
significant shaping). This was not the cheapest way to do it (more machining), but it allows for the smoothest shifting and longest GC life."
I'm not endorsing this cog until after a couple chain changes but have my fingers crossed.
