Topic Name: Advice please -- putting aerobars on a Flash
on: January 27, 2012, 07:15:22 AM
EDMountain
« on: January 27, 2012, 07:15:22 AM » |
Got a used 2010 Flash...it's wonderful. (I don't feel worthy of it...yet.) I'm still learning about it... and wondering how to get aerobars onto it for some loooong rides. Thanks!
Reply #1 on: January 27, 2012, 08:05:52 AM
EDMountain
« Reply #1 on: January 27, 2012, 08:05:52 AM » |
also, fyi, i have a carbon crank bros handlebar (a riser)... thanks
Reply #2 on: January 27, 2012, 01:18:11 PM
Reply #3 on: January 27, 2012, 01:50:17 PM
EDMountain
« Reply #3 on: January 27, 2012, 01:50:17 PM » |
thanks for all that. here's what i've got to work with. see pic. how could i get a Fred bar on here, you think?
Reply #4 on: January 27, 2012, 08:51:37 PM
« Reply #4 on: January 27, 2012, 08:51:37 PM » |
Neither of those options will work with your lefty (1.5 steerer). Best bet is to buy a set of quality alloy riser bars with a wide clamping area, to ensure the aerobars will get a firm grip with no slip. Assemble with carbon paste too. Some carbon bars do have a wide and thickened area for clamping, but I doubt that any (mainstream) mtb bar maker would build a bar to specifically accept clip ons the way that road bars do. Nice Flash too.
Reply #5 on: January 28, 2012, 08:12:37 PM
mbeardsl
« Reply #5 on: January 28, 2012, 08:12:37 PM » |
Pretty sure steerer tube is 1 1/8", not 1.5". I could be wrong.
If it's 1 1/8" you would simply need a longer steerer tube to mount a fred bar which you can find a lot of places.
Reply #6 on: January 28, 2012, 08:53:46 PM
mattyp
« Reply #6 on: January 28, 2012, 08:53:46 PM » |
second on getting a pair of alloy bars to put the aero bars on. one thing to look for is a wide bulged area; i have some race face deus and the bulge is a little short to get the aero bars on without custom shims that i have to improvise. i would also recommend the most adjustable aero bars you can get; like the profile t1; the benefit of a fred bar or a second stem is that they move the pads back because the top tube and stem on a typical cross country mountain bike is much longer than a tt bike that was designed to ride in the aero position. on my setup i ended up moving the pads back about 3 inches to get a comfortable position; which is more important for this application than pure aero-ness.
Reply #7 on: January 29, 2012, 08:33:52 AM
« Reply #7 on: January 29, 2012, 08:33:52 AM » |
Hmm... I don't think about that possibly being a 1.5 steer tube. If it's 1 1/8 then there may be some hope for the suggestions I posted up.
Reply #8 on: January 29, 2012, 09:16:08 AM
Curtis C
« Reply #8 on: January 29, 2012, 09:16:08 AM » |
I am pretty sure the steer tube on that bike is neither 1 1/8 or 1 1/5. It is closer to 1 1/5, but cannondale built it just far enough off to try and limit user to only cannondale stems.
Sorry I cant help with Fred Bar info
Curtis
« Last Edit: January 30, 2012, 01:47:53 PM by Curtis C »
Reply #9 on: January 29, 2012, 03:16:36 PM
« Reply #9 on: January 29, 2012, 03:16:36 PM » |
I just measured one of the 2012 Flashs in our shop, steerer measures 39.6mm, 1.5" = 38.1mm.
Reply #10 on: January 29, 2012, 03:29:26 PM
mbeardsl
« Reply #10 on: January 29, 2012, 03:29:26 PM » |
Well, in that case, a custom stem like fullyloaded has in his DIY GPS mount thread would be my option if $ didn't matter  With the lefty I think I'd want the extra room vertically as the bar is already a bit cramped with the top of the fork on the left side. And like others have said, you may want a more upright position than what the bar monted option will give you. Thanks for the fact checking Area54, I stand corrected.
Reply #11 on: January 29, 2012, 05:57:46 PM
MidSouth
« Reply #11 on: January 29, 2012, 05:57:46 PM » |
mbeardsl - do you have a line on someplace that may have some FredBars? I have been searching for about a year without any luck. Siren isn't producing any at this time for some reason.
Reply #12 on: January 29, 2012, 07:33:09 PM
« Reply #12 on: January 29, 2012, 07:33:09 PM » |
All good, quite the opposite in fact, as my 1.5" did not equal 39.6mm.
Reply #13 on: January 30, 2012, 11:58:33 AM
mbeardsl
« Reply #13 on: January 30, 2012, 11:58:33 AM » |
No, fullyloaded has his made by Moots so I'd start there as they clearly know what they're doing and you wouldn't have to explain what it is. If I were looking for one I'd personally go down the street here in NC to Jim Kish and ask nicely. I'd think any custom builder could/would knock one out pretty quickly. And if in steel instead of Ti probably quite cheaply too.
