Pages: [1] 2
  Topic Name: Attach Bottle Cage if No Braz-ons? on: October 12, 2014, 02:06:04 AM
bikepackinggood
« on: October 12, 2014, 02:06:04 AM »
Hi, I'd like to attach a bottle cage below the down tube, but my bike doesn't have braze-ons there. Suggestions for a clamp on system?
My down tube is wide and square.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #1 on: October 12, 2014, 11:12:43 PM
« Reply #1 on: October 12, 2014, 11:12:43 PM »
Hose clamps will confirm to a wide variety of shapes.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #2 on: October 13, 2014, 04:39:04 AM
harryonaspot
« Reply #2 on: October 13, 2014, 04:39:04 AM »
Two Fish makes a velcro on bottle cage
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #3 on: October 13, 2014, 06:55:31 AM
« Reply #3 on: October 13, 2014, 06:55:31 AM »
Hose clamp at the bottom zip tie the top then use a Velcro strap to secure the bottle so the strap takes a lot of the weight as well. Used this system to fork mount bottles that were only used at top off points.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #4 on: October 13, 2014, 10:07:07 AM
« Reply #4 on: October 13, 2014, 10:07:07 AM »
Add some inner tube rubber under those hose clamps and you should be good. Prevents paint scratching and slippage.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #5 on: October 13, 2014, 12:07:56 PM
« Reply #5 on: October 13, 2014, 12:07:56 PM »
right just I just used some gorilla tape on the fork legs but you'll need something with some bite rather then straight up metal on metal.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #6 on: October 14, 2014, 03:24:14 AM
Dusza
« Reply #6 on: October 14, 2014, 03:24:14 AM »
Duct tape with some tube scraps has done wonders for me. Used for down tube mounted Salsa Anythining cage carrying Kleen Kanteen 64 oz full of water.
It's not the prettiest solution but neither are hose clamps.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #7 on: October 17, 2014, 07:57:39 AM
WatermelonSugar
« Reply #7 on: October 17, 2014, 07:57:39 AM »
I've used hoseclamps with inner tubes underneath for extra grip on non round tubes but found that after a few rough days out on the trail things started to shift a a bit.
Elite do these little adjustable mounts
http://www.wiggle.co.uk/elite-vip-bottle-cage-clamps/
but I'm not sure how much better they would be, especially on the rough stuff or on square tubes.
« Last Edit: October 17, 2014, 08:03:31 AM by WatermelonSugar » Logged
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #8 on: October 17, 2014, 08:54:05 AM
MPS
« Reply #8 on: October 17, 2014, 08:54:05 AM »
I just posted that in another thread, but the solution fits here as well: Monkii cage by Free Parable design.
www.unlocked-achievements.com - Cycling to every country in the world
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #9 on: October 24, 2014, 03:09:35 PM
adamgnewman
« Reply #9 on: October 24, 2014, 03:09:35 PM »
TwoFish makes tons of stuff. Under the downtube is one of the few places where I would use it, since it has a tendency to swing around on fork legs, but the weight of the bottle keeps it pointing down on the downtube. I have one that fits a Nalgene bottle, and I know they make ones that fit the huge Hydroflask growlers.
http://www.twofish.biz/bike.html
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #10 on: October 24, 2014, 04:31:46 PM
« Reply #10 on: October 24, 2014, 04:31:46 PM »
Just go to a bike shop and have some rivnuts installed.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #11 on: October 28, 2014, 09:53:36 PM
ABfolder
« Reply #11 on: October 28, 2014, 09:53:36 PM »
I use this on a round down tube on an eighties mtn bike adjusted for touring: http://www.ebay.ca/itm/Bike-Gizmo-Bottle-Cage-Mounting-Adapter-/110611455975 . After a couple thousand miles this summer, it's still doing fine.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #12 on: November 04, 2014, 06:57:04 AM
bicyclehobo
« Reply #12 on: November 04, 2014, 06:57:04 AM »
I am running a carbon suspension fork, a full frame bag, a set of home made feedbags, and a viscacha seat bag. I would like an option to carry additional water.
I'm not clamping anything on the carbon fork. My seatbag and frame bag are full. My feedbags will carry two bottles and I can have a 2 liter bottle bag in the framebag.
Have a look at the photo I have attached. It would be pretty easy to fabricate a wider version of this that would be attached to the saddle rails and would not interfere with the seatbag. The bottles would face to the side instead of to the back on this version. These would be empty most of the time but would be an option when I needed extra water.
Any thoughts?
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #13 on: November 04, 2014, 07:34:26 AM
« Reply #13 on: November 04, 2014, 07:34:26 AM »
https://joecruz.wordpress.com/2011/10/17/attaching-extra-bottle-cages-to-pugsley/
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #14 on: November 04, 2014, 09:10:43 AM
bicyclehobo
« Reply #14 on: November 04, 2014, 09:10:43 AM »
I have no braze-ons whatsoever down there...but thanks for sharing. It would be better to keep water lower and I am certain that I can come up with a way to create a mount point for a cage that will work. I appreciate the links and photos. Thanks!
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #15 on: November 05, 2014, 07:23:00 AM
bobjenkins79
« Reply #15 on: November 05, 2014, 07:23:00 AM »
Hobo, I've used something similar to the setup you're suggesting, and the only downside I've experienced is that the cages willl loosen and/or the bottles pop out and you don't know about it until you reach back there for a bottle.
Every year at Dirty Kanza you see bottle cages (with the bottle still in them) after those bottle mounts have rattled apart
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #16 on: November 05, 2014, 08:35:28 AM
bicyclehobo
« Reply #16 on: November 05, 2014, 08:35:28 AM »
Thanks for the tip Bob. I have never used a bottle mount there and I appreciate that you share the experience and I don't have to learn the hard way.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #17 on: November 05, 2014, 08:58:08 AM
« Reply #17 on: November 05, 2014, 08:58:08 AM »
They pop out of form cages to. Use a rubber o ring from the hardware store or an old toe strap. voille ski straps work well too.
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #18 on: November 05, 2014, 04:32:32 PM
Bedrock
« Reply #18 on: November 05, 2014, 04:32:32 PM »
Sorry, I can't hold out any longer. Stand by for shameless product promotion.
The Honaker Hydro Pack holds a standard Nalgene bottle (1 liter), attaches with velcro and has Hypalon on the straps to keep it in place. Thoroughly tested and expedition proven. No aluminum to fatigue and break, no braze ons or riv-nuts to pull out.
Bedrock Bags - Andrew Wracher
  Topic Name: Attach Bottle Cage if No Braz-ons? Reply #19 on: November 06, 2014, 06:22:48 AM
bicyclehobo
« Reply #19 on: November 06, 2014, 06:22:48 AM »
I am riding a 26er with a suspension fork...you have some nice bags though. Thanks for the link!
  Pages: [1] 2
