  Topic Name: Bar mount for Garmin Etrex 30x on: March 08, 2016, 04:05:02 AM
Get Mounted
« on: March 08, 2016, 04:05:02 AM »
Hi,
I've just bought an etrex. I'm wondering what mount most people are using?
Regards,
GM
  Topic Name: Bar mount for Garmin Etrex 30x Reply #1 on: March 08, 2016, 05:20:09 AM
« Reply #1 on: March 08, 2016, 05:20:09 AM »
I bought the Garmin mount for my etrex 30x. The problem is that it likes to slip around when jarring the bike through rough terrain. I positioned it where I wanted it and used some adhesive to mount the rubber pad that comes with it to the bar on my bike. it is rock solid now.
But still a crappy design overall.
  Topic Name: Bar mount for Garmin Etrex 30x Reply #2 on: March 08, 2016, 06:52:39 AM
« Reply #2 on: March 08, 2016, 06:52:39 AM »
I rather like that mount. The hard part is getting the zip ties tight enough. On your stem it is no problem, and it won't slip at all, but on the handlebars they need to be tight. I use a zip tie gun to get it super secure.
I should note, I think there is something wrong with the back of my garmin because i had to file away at it for a while to get it to fit into the mount properly and actually release.
  Topic Name: Bar mount for Garmin Etrex 30x Reply #3 on: March 08, 2016, 07:36:12 AM
« Reply #3 on: March 08, 2016, 07:36:12 AM »
using the garmin mount. i added a bit of rubber that is thicker than the stock piece to the underside. when i use the zip tie gun to snug it down it stays put stem or bars... but i prefer stem.
add a leash to your unit though... just in case.
Krampus Cockpit by Mike, on Flickr
  Topic Name: Bar mount for Garmin Etrex 30x Reply #4 on: March 08, 2016, 07:38:21 AM
« Reply #4 on: March 08, 2016, 07:38:21 AM »
Nice looking rig.
  Topic Name: Bar mount for Garmin Etrex 30x Reply #5 on: March 08, 2016, 09:17:03 AM
Yagi
« Reply #5 on: March 08, 2016, 09:17:03 AM »
+1 on the leash.  I also prefer the stem for mounting, but my stem is too short.  I bought one of these:
https://paulcomp.com/shop/components/stem-cap-light-mount/
Works great, and puts the GPS a little closer to me.  It's held up wonderfully on the last 3 tours.
  Topic Name: Bar mount for Garmin Etrex 30x Reply #6 on: March 08, 2016, 09:49:23 AM
« Reply #6 on: March 08, 2016, 09:49:23 AM »
I have one of those. I just zip tie it around the bar / stem joint. Works just fine.
  Topic Name: Bar mount for Garmin Etrex 30x Reply #7 on: March 08, 2016, 11:27:17 AM
« Reply #7 on: March 08, 2016, 11:27:17 AM »
I use the Garmin mount. Usually have bar tape wrapped around my bars for bikepacking to protect my carbon bars which also gives the mount something to sink into. Cinch the zip ties down tight, never had any issues. Also absolutely use a lanyard on the GPS tied to the bars. My has popped off a couple times and I've been glad to find it dangling from my bars and not in a ditch 10 miles back.
  Topic Name: Bar mount for Garmin Etrex 30x Reply #8 on: March 08, 2016, 08:28:54 PM
Get Mounted
« Reply #8 on: March 08, 2016, 08:28:54 PM »
When you mention you use the garmin mount, is this the mount to which you are referring?
http://www.amazon.com/RUGGED-HANDLEBAR-BICYCLE-HOLDER-GARMIN/dp/B00DJBGJYS
https://buy.garmin.com/en-GB/GB/shop-by-accesories/mounts/bike-cart-mount/prod11411.html
  Topic Name: Bar mount for Garmin Etrex 30x Reply #9 on: March 08, 2016, 08:52:59 PM
bpeschka
« Reply #9 on: March 08, 2016, 08:52:59 PM »
Yes, the one at the Garmin link.  Mine has survived 3 TD's.  A lanyard is essential, although I've never had mine pop off except once when I hadn't 'clicked' the GPS back in all the way.  My lanyard is basically small nylon cord.
  Topic Name: Bar mount for Garmin Etrex 30x Reply #10 on: March 09, 2016, 01:52:49 AM
Get Mounted
« Reply #10 on: March 09, 2016, 01:52:49 AM »
Great, thanks for the replies!
  Topic Name: Bar mount for Garmin Etrex 30x Reply #11 on: September 24, 2018, 02:32:36 PM
fmanolas
« Reply #11 on: September 24, 2018, 02:32:36 PM »
Hello!
I prefer to use the Garmin Tether instead Garmin's bike holder.. It is secure and very fast to put or remove.. Plus it makes NO scratches to the handlebar. There's not necessary to put any tie-wraps or something similar to secure..
