Topic Name: Best disc rim for Specialized Renegade 2Bliss - tire
on: June 25, 2017, 10:57:58 AM
Erik_A
« on: June 25, 2017, 10:57:58 AM » |
What is the best rim for Specialized Renegade 1.8" 2Bliss tires?
I tried the previous/ original Stan's Arch wheel and it was an exercise in futility trying to stretch it onto the rim.
What is a good 32 hole fairly light, but strong disc rim. I assume that a 21mm or 23mm internal width is best for the 1.8" tire. I will be using this for a disc gravel/ bikepacking build.
Also, should a look for a UST or TCS rim to work best with the Specialized 2Bliss bead to set up tubeless?
Reply #1 on: June 27, 2017, 06:19:02 PM
sashax
« Reply #1 on: June 27, 2017, 06:19:02 PM » |
I assume you're talking 29er here, cause Stans rims and Spesh tires are known incompatible on 29" wheels. I've gotten it to work occasionally, but only that. I believe UST rims at least will work. Not sure about TCS.
Personally I'd fit the tire to the rim, not the other way around, so I don't have good advice about what rim to fit to that tire.
Reply #2 on: June 27, 2017, 08:10:28 PM
Erik_A
« Reply #2 on: June 27, 2017, 08:10:28 PM » |
... but they are my new favorite tires!
Reply #3 on: June 29, 2017, 01:21:25 PM
« Reply #3 on: June 29, 2017, 01:21:25 PM » |
A good rule of thumb in 29" is that if the tire is too tight to fit on a Stans rim, then it is an ideal fit on any UST or TCS rim.
I'd look at the WTB Frequency i19 or i23.
Reply #4 on: June 29, 2017, 01:24:26 PM
Erik_A
« Reply #4 on: June 29, 2017, 01:24:26 PM » |
Thanks for all of the advice!
