  Topic Name: Blackburn EX-1 Disc on 29er?? on: August 25, 2011, 07:37:17 AM
kkjellquist
« on: August 25, 2011, 07:37:17 AM »
Anyone know if this rack fits 29ers?  Blackburn site says 700c and I have read Blackburn says it does NOT fit 29er wheels, but I tend to not believe everything bike companies say.
  Topic Name: Blackburn EX-1 Disc on 29er?? Reply #1 on: August 26, 2011, 10:22:26 AM
kkjellquist
« Reply #1 on: August 26, 2011, 10:22:26 AM »
Answered my own question at the LBS today.  No go on 29ers.  It's really frustrating too...if the rack was just 1/2" taller it would fit just fine. BangHead  Someone at Blackburn really dropped the ball on this product.
  Topic Name: Blackburn EX-1 Disc on 29er?? Reply #2 on: August 28, 2011, 01:10:09 PM
MM-on-POINT
« Reply #2 on: August 28, 2011, 01:10:09 PM »
Got a ex1 disc rack on and trek Cobia 29er fits with good clearance,not sure why the ex1 disc didn't fit when you tried it, post a pic if you could so we can see the issue and try help glasses2
« Last Edit: August 28, 2011, 01:20:51 PM by MM-on-POINT » Logged
  Topic Name: Blackburn EX-1 Disc on 29er?? Reply #3 on: September 28, 2011, 07:09:12 AM
kkjellquist
« Reply #3 on: September 28, 2011, 07:09:12 AM »
So I finally made it over to my LBS to try the EX-1 Disc on my Salsa Dos Niner.  Without any mods it does fit but just barely (< 5mm) over my Crossmark rear tire.  Tires with a taller tread would probably rub the bottom of the rack.  However, the stays on the rack have a decent bend, and I was able to straighten/lengthen them fairly easily.  With the minor mod I have a solid 1cm of clearance and could get a bit more if needed.  I can foresee some issues with mud, but I'll tackle that problem when it arises.
In conclusion I would say the EX-1 is a solid budget rack that does work for 29ers without rack mounts.
  Topic Name: Blackburn EX-1 Disc on 29er?? Reply #4 on: September 28, 2011, 12:12:07 PM
MM-on-POINT
« Reply #4 on: September 28, 2011, 12:12:07 PM »
On my current frame now I actually have pannier lugs at the back but no lugs on the seat stays so i bought some 40mm x 5mm bolts and bolted the rear in to lugs instead of of using the hub q/r. Hope this gives you some insight
  Topic Name: Blackburn EX-1 Disc on 29er?? Reply #5 on: October 01, 2011, 12:55:27 PM
cousinmosquito
« Reply #5 on: October 01, 2011, 12:55:27 PM »
Don't forget the freeload rack. Will fit on practically  anything. Had it on my santa cruz superlight, currently on my karate monkey.
  Topic Name: Blackburn EX-1 Disc on 29er?? Reply #6 on: October 01, 2011, 03:07:29 PM
« Reply #6 on: October 01, 2011, 03:07:29 PM »
Can you fab up some beefy extension brackets? I had an issue on our tandem, not being able to use a disc rack AND a BOB trailer skewer, so fabbed up some extensions out of 6mm alloy flatbar.
« Last Edit: October 01, 2011, 03:11:13 PM by Area54 » Logged
