Home
Forums
Routes
Gear Reviews
How to contribute
Personal setups
Trip reports
Ultra records
Help
Search
Login
Register
Bikepacking.net forums
Forums
Question and Answer
Cable routing issues?
Pages: [
1
Topic Name: Cable routing issues?
on: September 27, 2014, 06:39:56 PM
Mxhdroom
on:
September 27, 2014, 06:39:56 PM »
Hi,
I'm thinking about buying a 2015 Rocky Mountain Trailhead (a minor upgrade to my old Fusion) for trail riding and hopefully some shorter-trip bikepacking. The Trailhead has its cables routed along the bottom of the top tube on their way towards the rear of the bike; the derailleur cables are "open" (not enclosed in cable housing) and I'm worried that a frame bag would interfere with rear derailleur operation.
Does anyone have any experience with this type of design or opinions as to if it is indeed a problem?
Gary
Avid and envious blue (and pink, and yellow...) dot follower.
Reply #1
on: September 28, 2014, 04:50:05 PM
harryonaspot
Re: Cable routing issues?
Reply #1 on:
September 28, 2014, 04:50:05 PM »
I don't thiNk it should be a problem. You could ease the tightness on the top tube straps of your frame bag, or try putting those thin sleeves over the exposed cable. Or even run solid housing. If you like the bike, you will figure something out for the occaisonal trip
Reply #2
on: September 29, 2014, 03:44:15 PM
AlasdairMc
Reply #2 on:
September 29, 2014, 03:44:15 PM »
I'd be more worried about the increased friction damaging the frame or the frame bag. If you've got something holding a cable closer to the frame, I reckon it would be more likely to rub against the frame and cause damage. Just fit full outers instead as they shift better and take less maintenance (i.e. none)
Reply #3
on: September 29, 2014, 04:36:36 PM
Reply #3 on:
September 29, 2014, 04:36:36 PM »
I just updated my Fargo and used the Jagwire stuff that has thin housings for the areas between frame hard points. I'm using it under the down tube to keep things shifting smoothly when I run the full frame bag (all of the time!).
www.littlecirclesvt.com
Reply #4
on: April 03, 2015, 09:25:25 PM
Mxhdroom
Reply #4 on:
April 03, 2015, 09:25:25 PM »
I solved the problem by buying a Marin Nail Trail 9.6 with fully enclosed cables. I think I'll upgrade to Jagwire next winter, but for now everything works fine.
Thanks everyone for the input.
Ride on.
Gary
Reply #5
on: April 11, 2015, 03:20:07 PM
squishware
Reply #5 on:
April 11, 2015, 03:20:07 PM »
I had this issue on my Redline D460. I dremeled off the smaller end of the cable stops to allow full length cable housing.
Pages: [
1
Please select a destination:
Site
=> Site issues / Suggestions
Forums
=> Bikepacking
=> Question and Answer
=> Routes
=> Ultra Racing
=> Winter bikepacking
=> Classifieds
Powered by SMF 1.1.21
SMF © 2015, Simple Machines
Loading...
