Since I started getting into bike packing 2 years ago I have only used, built, and experimented with alcohol stoves. I really like them but their inconsistency with climate, wind, starting water temp, and other things drives me nuts. You finally get a system of efficiency figured out and then the next time you use it your system doesn't perform what it did the last time lol. That said I am not getting rid of my alcohol setup as I know there will still be trips where I will prefer it but yesterday I did pull the plug and order a Snowpeak Gigapower stove. Yeah I did it.
I'm trying to still be as minimalistic as possible (is that even a thing anymore once you venture into a isobutane stove setup
). My pot setup has always been a 20 ounce Stanley pot and one of those 18 ounce Ozark trail pots from Wal Mart. The Stanley pot fits inside the 18 ounce Ozark Trail coffee cup and they sit nicely on my Salsa Anything cage on my fork. With my old alcohol setup everything fit inside my Stanley pot (stove, windscreen, lighters, pot stand,) but I am aware that with my new stove setup I will probably not be able to fit a 4 ounce fuel canister inside my pot and for sure not the 8 ounce size. Heck I even contemplated going with a couple of those Ozark Trail cups (one for coffee/drink and one as a pot) since they hold 2 cups of liquid and that's more than enough for anything I ever cook anyways and the lid from my Stanley pot fits the mugs perfectly. Those cheap mugs have a little wider base than the Stanley pot so they may work better on my new stove but I won't know anything until I receive it in the mail and get to test it out. I still want to try and stay with a small pot (20 ounces or smaller) instead of one of those larger pots to keep space on the bike minimal.
All I do on my trips is boil water for ramen noodles or for dried bag meals (Mountain House, Bear Creek etc) as well as my coffee. The rest of my food is usually trail mix or granola bars. So with that being said......I would be interested in seeing other's pot and cookware setups.
