  Topic Name: etrex 20: max. routpoints per route? on: July 21, 2015, 03:03:24 PM
F0neb0ne
« on: July 21, 2015, 03:03:24 PM »
Hi all,
I am looking for info on how many routepoints I can pack into a single route file to make sure the etrex 20 does show all the points on screen and delivers the "beep" when I cross one of the points.
There is a limit (i ran into it), but I don't know whether its 400 or 480 or something else. When you happen to cross it, the etrex just stops showing any points and no route either. Its kinda annoying. If you change to a track-file with exactly the same amount of points and the same points, it still shows you a nice line all through the map, but you don't get the "beeps" which do help with orientation especially when you are riding fast.
I did not find the necessary info on the garmin page though...
Thanks for your help!
  Topic Name: etrex 20: max. routpoints per route? Reply #1 on: July 22, 2015, 11:59:11 AM
dh024
« Reply #1 on: July 22, 2015, 11:59:11 AM »
From the Garmin Support website at https://support.garmin.com/support/searchSupport/case.faces?caseId=%7B0b02f820-03db-11e0-e050-000000000000%7D
- limit of 200 routes at 250 points per route
--David
