Topic Name: GPS unit for the divide?
on: February 12, 2016, 12:07:11 PM
Jbennett
« on: February 12, 2016, 12:07:11 PM » |
I'm doing some research on which GPS unit would fit my needs best for the divide. I currently have a Garmin 1000 that I plan to use as well. Will the eTrex 35 fit all of the way points without issue? Trying to understand the differences between the units and it seems to boil down to memory and how many way points they support. I don't mind spending a bit more if it means I'm getting a unit that doesn't limit me. Thanks for any input!
Reply #1 on: February 15, 2016, 04:34:02 PM
Hadfield
« Reply #1 on: February 15, 2016, 04:34:02 PM » |
Just got the etrex 30x and it works great
Reply #2 on: March 03, 2016, 06:32:44 PM
« Reply #2 on: March 03, 2016, 06:32:44 PM » |
I took a Garmin 800 with me last year and used the smaller 10,000 point track on it. The route loaded quicker with the smaller track. I had no issues finding my way along the route with the 10,000 point track. Etrex and Dakota units work well and can be powered by regular batteries.
Reply #3 on: April 14, 2016, 08:28:08 PM
vulpes_vulpes
« Reply #3 on: April 14, 2016, 08:28:08 PM » |
Can someone explain why I would spend 100 dollars more for the etrex 30x vs. the 20x? Is the compass/barometer necessary or just neat?
Reply #4 on: April 15, 2016, 04:10:21 AM
pavementgraveldirt
« Reply #4 on: April 15, 2016, 04:10:21 AM » |
^ In my experience the 30 was 'cool' but the 20 was more practical. Didn't ever need a compass or barometer for my usage.
I killed my 20 somehow, just stopped loading one day. Got it taken care of no worries. I now have a 10 because they were on sale and at the time I wasn't using the map features just tracking. Works great.
If I was buying again today I would be looking into the touch screen options.
Reply #5 on: April 15, 2016, 09:56:47 AM
« Reply #5 on: April 15, 2016, 09:56:47 AM » |
I opted for the 30x. It was only $70.00 more than the 20x. I love it. I wouldn't recommend getting any of the mapping packages. There are many available for free or donation.
Reply #6 on: April 20, 2016, 05:15:36 PM
Reply #7 on: April 20, 2016, 07:07:22 PM
dh024
« Reply #7 on: April 20, 2016, 07:07:22 PM » |
I'm doing some research on which GPS unit would fit my needs best for the divide. I currently have a Garmin 1000 that I plan to use as well. Will the eTrex 35 fit all of the way points without issue? I see that the newer eTrex 35 actually has some disadvantages over the older eTrex 20/30: it is slightly heavier, it has a similar sized screen (touch) but at half the pixel resolution, and it has less than 2/3 of the expected battery life. I was going to upgrade to the touch screen eTrex 35 from my 30 unit, but I think I will pass now that I spotted those differences. The bad thing is, I see the eTrex 20/30 units are becoming harder to find as the newer "improved" GPS has come out. https://buy.garmin.com/en-US/US/catalog/product/compareResult.ep?compareProduct=156873&compareProduct=518048&compareProduct=518046
--David
Reply #8 on: April 21, 2016, 11:26:00 PM
F0neb0ne
« Reply #8 on: April 21, 2016, 11:26:00 PM » |
The 20 does just fine, but I would get the older version without the touch screen. In my experience, you need to switch the scale of the map often, and with the buttons on the side of the eTrex, I don't really have to look there to adjust. On a touch screen, you have to look at it closely etc... too much distraction from the path right in front of you.
I downloaded map packs for MTB and openstreetmap, and they were totally sufficient, so save your $ and don't buy the map packs from Garmin.
Reply #9 on: April 22, 2016, 06:41:49 PM
« Reply #9 on: April 22, 2016, 06:41:49 PM » |
Actually, if you are using the Etrex 35 with the touch screen, navigating the map is a huge leap forward better. There are +/- buttons on the map itself, but you can just pinch to zoom, as well as swipe to move the map around. That's, IMHO way better than having to use the buttons on the side, or Dog help you, navigate via the nubbin'. The screen size of the 35 is quite a bit larger than the 20/30.
If though, all you need to is to follow a track line, there's little difference, unless you're zooming in/out all day long.
Reply #10 on: April 22, 2016, 11:38:32 PM
F0neb0ne
« Reply #10 on: April 22, 2016, 11:38:32 PM » |
Well I had to follow a given track all day long, so all I needed to do was zooming in and out quite often, depending on how tricky the track was hidden in the woods etc.
For free navigation without following a track... well... all GPS devices with a small screen suck imho, because its almost impossible to get a good overview of the area and then to decide with small track to actually choose to go where I want.
Reply #11 on: April 23, 2016, 07:24:33 AM
Hadfield
« Reply #11 on: April 23, 2016, 07:24:33 AM » |
Please someone point me in the right direction of which free maps I need to download onto my unit. To use my etrex 30 for tour divide, I'm assuming that I need a map set other than what comes with GPS. Then I download gpx files onto gps? Sorry not very good with electronics part. Thanks everyone
Reply #12 on: April 23, 2016, 08:16:28 AM
« Reply #12 on: April 23, 2016, 08:16:28 AM » |
http://www.gpsfiledepot.com/Although for the TD, there's no reason to really d/l any additional maps, just follow the line. The ACA maps give a good overview of resup points, etc.
Reply #13 on: April 23, 2016, 11:03:00 AM
Hadfield
« Reply #13 on: April 23, 2016, 11:03:00 AM » |
Thanks long ranger. I'm an idiot when it comes to these things
Reply #14 on: April 23, 2016, 12:10:46 PM
dh024
« Reply #14 on: April 23, 2016, 12:10:46 PM » |
Actually, if you are using the Etrex 35 with the touch screen, navigating the map is a huge leap forward better...
The screen size of the 35 is quite a bit larger than the 20/30. Actually, the eTrex 20/30 has a 2.2" diagonal screen, whereas the eTrex 25/35 units are 2.6", so they are slightly bigger. But the touch screen units have only half the resolution (160 x 240 pixels vs. the 240 x 320 pixel screens on the older eTrex 20/30 units). I posted a link to the stats above. I have long preferred the touch screen of my Garmin Oregon on the bike, but I have giving my eTrex 20 more attention lately, and I think I actually like it a lot better. Using the touch screen with gloves has always been a pain, especially in the rain. And I have gotten used to using the buttons on the eTrex, which I think are easier to use on the bike for me than the touch screen. Plus the touch units seem to use up battery power far quicker than the Oregon or eTrex touch units.
--David
Reply #15 on: April 23, 2016, 12:15:11 PM
dh024
« Reply #15 on: April 23, 2016, 12:15:11 PM » |
In addition to the maps on GpsFileDepot, you can also create custom downloads of routable OpenStreetMap map images (and installs for Garmin Basecamp/Mapsource) at: http://garmin.openstreetmap.nl/. The site includes some very good instructions for obtaining and installing the maps.
--David
Reply #16 on: April 23, 2016, 02:03:12 PM
Hadfield
« Reply #16 on: April 23, 2016, 02:03:12 PM » |
Thanks guys for the help.
Reply #17 on: May 01, 2016, 09:10:47 AM
taprider
« Reply #17 on: May 01, 2016, 09:10:47 AM » |
anything combine a SPOT equivalent transmitter with a GPS receiver?
Reply #18 on: May 09, 2016, 03:27:12 PM
stever121051
With my wife LuAnne
« Reply #18 on: May 09, 2016, 03:27:12 PM » |
Anyone have the Garmin GPS 64 series?
and how do you feel about it
worthy device for the Great divide
thanks Steve
Reply #19 on: May 09, 2016, 08:23:46 PM
dh024
« Reply #19 on: May 09, 2016, 08:23:46 PM » |
The Delorme InReach Explorer might be what you are looking for. It also has satellite texting for two-way communications, which is an advantage over the SPOT devices.
--David
