  Topic Name: H Bars on: August 16, 2010, 02:58:27 AM
1speed
« on: August 16, 2010, 02:58:27 AM »
Anyone running H Bars? How are you setting up your shifters and brake levers? Do you like them?
  Topic Name: H Bars Reply #1 on: August 16, 2010, 10:55:56 AM
sportsman
« Reply #1 on: August 16, 2010, 10:55:56 AM »
love my jones bars.. brake levers are fine and comfy, but what are "shifters"?
  Topic Name: H Bars Reply #2 on: August 16, 2010, 01:33:32 PM
trojobikeho
« Reply #2 on: August 16, 2010, 01:33:32 PM »
I've run the ti H-Bar for years on my SS. I recently put a titec version on the SS and put the ti H-Bar on my geared full suspension bike. I run the XTR integrated brake/shifters so only had to mount one component forward of the bar/grip intersection. I wish I would have done this years ago as it makes this bike much more comfortable. the jones web site also shows some geared set ups with thumb shifters. I think any traditional trigger shifters would be difficult to get set up correctly.
  Topic Name: H Bars Reply #3 on: August 16, 2010, 03:53:55 PM
1speed
« Reply #3 on: August 16, 2010, 03:53:55 PM »
Too funny! This will be the first geared bike I've built in a long time. I am having the frame built with sliding dropouts so I have options.
  Topic Name: H Bars Reply #4 on: August 16, 2010, 03:56:46 PM
1speed
« Reply #4 on: August 16, 2010, 03:56:46 PM »
I'm going to try and run SRAM X-9 triggers. I dislike Shimano so much I would probably change the bar before I switched from SRAM. I've seen some pictures on the web of H Bars set up with triggers and they look awkward, just wondering if anyone here had any experience with them.
  Topic Name: H Bars Reply #5 on: August 16, 2010, 06:29:10 PM
« Reply #5 on: August 16, 2010, 06:29:10 PM »
like em so far, ended up flipping them upside down. haven't got long long rides on em (more than 3 hours), and the ergons are going to come off when i feel like taping.
currently running the bike tringlespeed, so i have a thumb shifter on the left for moving a front mech... 22,32,44 turning an 18t with a paul melvin for pulling the little one around.
  Topic Name: H Bars Reply #6 on: August 16, 2010, 09:17:02 PM
Lonesome Luddite
« Reply #6 on: August 16, 2010, 09:17:02 PM »
As far as comfort goes I like my Titec H-bars.  The sweep is good, and with the Ergons I can ride all day (3x100+ mile gravel cruises) w/o a problem.  The one problem I do have with them is not being able to place the brake levers on the outside part of the bar.  While I haven't had any problems with the setup the way it is, I'm afraid that I'd have trouble reaching the brakes while tackling serious singletrack.  I suppose I could cut down the Ergons, but I can't quite bring myself to do it yet.
This is my Pugsley by the way, set up w/ Deore brake levers and Suntour shifters, which I use on gravel, moderate singletrack, and snow (of course).
-Matt Maxwell
  Topic Name: H Bars Reply #7 on: August 17, 2010, 12:09:44 AM
Damnitman
« Reply #7 on: August 17, 2010, 12:09:44 AM »
I run my brakes on the main portion of the bar and have my thumbshifters on the horns, which I cut down to functional stubs (long enough for mounting the shifters) so my pogies would fit better...Funny, I was recently evaluating switching from double-wrapped bars to ergons...just didn't figure their designed-ergonomics would work as well on H / swept bars...you like them on h bars though...hmmmm...
  Topic Name: H Bars Reply #8 on: August 17, 2010, 08:18:58 AM
DiDaDunlop
« Reply #8 on: August 17, 2010, 08:18:58 AM »
I have a Titec H bar. And I am using X9 shifters on it.
I used the matchmaker XX system to get the shifters on the main bar portion. Works like a charm altough you have to learn how to use it.
  Topic Name: H Bars Reply #9 on: August 17, 2010, 06:18:05 PM
1speed
« Reply #9 on: August 17, 2010, 06:18:05 PM »
...I used the matchmaker XX system to get the shifters on the main bar portion. Works like a charm altough you have to learn how to use it.
I had not seen the Matchmaker XX's before, looks like I'll have to order them since I thought that would be the best place to run the shifters but didn't know how to do it. Thanks!
  Topic Name: H Bars Reply #10 on: August 19, 2010, 06:01:23 AM
Metro
« Reply #10 on: August 19, 2010, 06:01:23 AM »
I had the same problem when I went with a geared setup. Settled on the Shimano Dual Control shifters and quickly remembered why I went SRAM a few years ago. Still, it did the trick.
I had considered using the SRAM match maker to get some X9 shifters and Juicy 7 brakes going on the bars but from looking at multiple pics on the net it didn’t seem like it would jive. Looks like if you separate the shifter from the brake via the matchmaker bracket you can at least get the shifter mounted. Nice work DidaDunlop!
  Topic Name: H Bars Reply #11 on: August 30, 2010, 11:41:34 AM
aljee
« Reply #11 on: August 30, 2010, 11:41:34 AM »
i am using an alfine trigger shifter with the h-bar. at first i really didn't like it. i couldn't wrap my meatmitts around the grips with out the triggers getting in the way. so i cut them down. now it is great!
you can see a photo of my hack job here: http://www.flickr.com/photos/40010668@N06/4292907197/#in/set-72157622277279413/
i also cut off that damn "gear window" cause it made a rattley sound. see that here: http://www.flickr.com/photos/40010668@N06/4293649352/#in/set-72157622277279413/
