bwanajames
« Reply #4 on: December 31, 2017, 10:26:29 PM » |
I guess I was thinking in terms of sprung vs. unsprung weight. A lot of motorcycle forks are inverted to reduce unsprung weight and realize a more responsive suspension and better handling. 10 lbs carried on a front suspension fork will have a much greater effect on handling (and greater stress on suspension components) than 10 lbs in a frame bag.
Below are some findings with a little digging. I guess I've answered my own question. For me, I'll keep the front suspension free of gear.
Sprung weight: The complete chassis, including all the parts that are suspended above the suspension’s springs, is considered “sprung” weight. That includes the frame, engine, plastic, controls, saddle, upper fork tubes and shock body. It’s called sprung weight because springs are used to hold it up and to isolate it from the bumps that the wheels hit.
Unsprung weight: Unsprung weight is the mass that hangs below the springs (fork legs, hubs, brake calipers, rotors, spokes, rims, swingarm, linkage, tires, tubes and rim locks). Unsprung weight is more closely connected to the ground than the parts above it, because when you hit a bump, unsprung components compress into the chassis to absorb the impact.
NEGATIVE EFFECTS OF WEIGHT BELOW THE SPRINGS Your bike’s suspension is constantly moving. If it’s not compressing, it’s rebounding. At the top and bottom of the suspension’s stroke?whether fully bottomed, topped out or somewhere in between?the wheels must change direction as quickly as possible. The less weight hanging from the suspension components, the easier it is for the mass of the wheels to stop and accelerate in the opposite direction. It’s no secret that the quicker the wheel reacts, the better the suspension will be — because the next bump is coming faster than the mechanism can respond. It goes without saying that the less unsprung weight, the less strain will be placed on the pivots, springs and dampers. The lower the unsprung weight, the quicker the suspension reacts to bumps. The improvement is most significant over repetitious, high-frequency bumps (like braking and acceleration bumps). Why? The more weight you load on the wheels, the more the shock absorber has to struggle to bring the mass to a stop. As the damper struggles with the weight, the suspension packs, the wheels kick over the bumps and the bike becomes a handful.
BJ
