I've got a carbon 1 and it's a nice bike. I am on my second frame, I broke the original frame on the '10 CTR and it was my eventual downfall. It wasn't a spontaneous explosion, I broke 4 der. hangers on the race, one pretty spectacularly, and it eventually broke the drive side chain stay. My slightly modded med. is at about 19-1/2 pounds with real tires, so the combination is pretty light. That bike has seen almost 15,000 miles with little to no problems. It's a fairly stiff ride and contrary to some reports, rides like the 80 mm hardtail it is
I don't have any experience on the alloy version.
The lefty can be a bit temperamental for some. I don't know of any forks that can be serviced with a multi-tool in the field. I have 4 of them and know how to service/rebuild them. I have all the tools a Cannondale shop would have so my life is a bit easier, I also have a spare damper just in case. My experience is they are slightly more problematic than a Fox, but can be very reliable if you take care of them. Finding someone to service them is key, and can be a problem out of your home area. Only a Cannondale service shop will have the tools to work on them, they are very specific other than the bearing reset which only requires a Shimano external bb tool. I have taken that tool with me on extended trips, drilled some holes in it and milled it down a bit and it doesn't weigh much.
Never broke a hub so the wheel is a non issue unless you are looking to buy a complete wheel somewhere, otherwise they build up like any other wheel if you have the truing stand adapter.
