  Topic Name: Map cases on: April 30, 2014, 04:52:12 PM
offroute
« on: April 30, 2014, 04:52:12 PM »
What map case works for you?
I generally like larger ones. I had one with letter size viewable, but it bit the dust.
I'm trying to eliminate the load strapped to the handlebars next time out, so there may not be much to lash a map case to. Ideally the case would attach to bars and stem.
Thanks in advance!
  Topic Name: Map cases Reply #1 on: May 01, 2014, 02:21:41 AM
« Reply #1 on: May 01, 2014, 02:21:41 AM »
I use thick ziplocks available at stationery stores. Also use the Sea to Summit TPE cases, but mainly for kayaking when dry is a priority. On the bike they tend to get munched, dusty, dirty, muddy, tyre rubbed, stood on, rained on etc so easier to bin it (ziplock) when job is done and it's beyond repair with clear tape Smiley
  Topic Name: Map cases Reply #2 on: May 01, 2014, 02:18:18 PM
MattL
« Reply #2 on: May 01, 2014, 02:18:18 PM »
BarMap OTG is good if I'm not using my GPS.  You have to velcro it out to see letter size.
Ziplocs and binder clips is also good and super light.
I finished the 2013 TD.  I did the whole damn thing,
excluding the 2013 detours, in good style and—as
far as I know—totally in accordance with the rules.
  Topic Name: Map cases Reply #3 on: May 01, 2014, 03:47:35 PM
offroute
« Reply #3 on: May 01, 2014, 03:47:35 PM »
Thanks, guys!
