Surly says their new 3 inch Knard will fit a Flow
What fork fits 3.4 inch 29er tires?
Many rigid forks will take that beefy of rubber; I measured, and my fargo fork would take the knard with room to spare (it would almost take a larry on 50mm rims, based on what I have read on the web).
As to Flows and Knards, I would hesitate to use that narrow of rim with that wide of tire. The rabbit hole is almost twice as wide as the Flow, and surly's blog only mentions measurements on a P35. That's probably the narrowest rim I would use. If you consider "normal" widths, the ratio of rim width to tire width is usually less than 1:2.25, which would give a 34mm rim for the knard.
Check out the table at
http://www.schwalbe.com/gbl/en/technik_info/reifenmasse/index.php5?flash=1&gesamt=27&ID_Land=38&ID_Sprache=2&ID_Seite=141&tn_mainPoint=Technik&tn_subPoint= for some more guidance (note that the chart on that page is referring to inner rim width, fwiw).
