Topic Name: +Size tires on Fargo
on: January 20, 2015, 12:02:25 PM
southwestbackcountry
« on: January 20, 2015, 12:02:25 PM » |
Not interested in "mid-fat" or small rear tire options, I am wondering what options folks have come across for plus size tires on a full wheel set (Back too) on a Fargo. Rather than purchasing a Surly ECR or Krampus, I'm hoping to only have to up my tire size. I read an interesting piece regarding 27.5 X 2.8" tires on a fargo, but seems like there's no conclusive take on this issue in the article (found here: http://twentynineinches.com/2014/09/02/wtb-trailblazer-27-5-x-2-8-tires-exclusive-b-review-intro-part-2/ ). Be sure to read the article prior to commenting on the "2.8 inches" piece... I'm putting a dynamo hub into the wheel set, so, I want it to last and not be too much of an experiment. Takes, opinions, and experiences from anyone? Biggest size you've put on your rear wheel? widest rim? From the above article, this is Guitar Ted's pic of his Fargo with 27.5's on it:
« Last Edit: January 20, 2015, 01:11:47 PM by southwestbackcountry »
Alive and Well
Reply #1 on: January 20, 2015, 12:23:12 PM
« Reply #1 on: January 20, 2015, 12:23:12 PM » |
which fargo? a friend of mine is thinking about this very same thing... front should be easy, rear is the big question. with the alternator model you have a bit more room to play with. (and, FWIW, i moved to a Krampus for this reason, as well as for wanting a higher BB, and more 'mtb' feel) dyno up front on a rabbit hole. rohloff out back. IMG_4177 by mbeganyi, on Flickr can't really help - my fargo is gone...
Reply #2 on: January 20, 2015, 07:48:49 PM
« Reply #2 on: January 20, 2015, 07:48:49 PM » |
Does it matter which Fargo due to width? or how low the cranks are?
Alive and Well
Reply #3 on: January 21, 2015, 08:16:27 AM
« Reply #3 on: January 21, 2015, 08:16:27 AM » |
If its a Gen 1 I don't think you'll get it in the front fork. If its a Gen 2 the front should work with a Rabbit Hole / Knard. The rear is limited to probably going to a smaller rim size. If its a Gen 3 with the alternator dropouts you have a *little* bit more wiggle room in the back because you can pull the alternators way back to gain some length at the BB. And I do believe that the Rabbit Hole / Knards fit in the Firestarter fork.
Reply #4 on: January 21, 2015, 01:21:42 PM
« Reply #4 on: January 21, 2015, 01:21:42 PM » |
I had the same question, and did some rough measurements with calipers on my Gen 2 Fargo. IIRC, I got 91mm front width, and -Edit- 78 mm rear. In short, I could easily run true 3" rubber on 50mm rims in the front, but the back will need something smaller. I am unwilling to drop the bottom bracket by running 650B+, so I am waiting until someone comes out with something in a true 2.5-2.6 inch width (on something like a P35).
« Last Edit: January 22, 2015, 06:07:38 PM by fotooutdoors »
Reply #5 on: January 21, 2015, 10:19:16 PM
Shilman
« Reply #5 on: January 21, 2015, 10:19:16 PM » |
Not sure if it helps or not, but I have the Racing Ralph's 2.4 (not the 2.35) on Rabbit Holes and that's the max that can fit in the rear on those rims.. It's not as fat as I wanted to go but I've been happy with it the last 2 years..
Reply #6 on: January 21, 2015, 10:43:10 PM
« Reply #6 on: January 21, 2015, 10:43:10 PM » |
Good suggestion Shilman. I'd really like wider, and if I can do it with a 27.5 wheel, it'd be great. I'll keep that set in mind though for sure. Thanks.
Alive and Well
Reply #7 on: January 22, 2015, 01:01:24 PM
« Reply #7 on: January 22, 2015, 01:01:24 PM » |
I had the same question, and did some rough measurements with calipers on my Gen 2 Fargo. IIRC, I got 91mm front width, and 74 mm rear. In short, I could easily run true 3" rubber on 50mm rims in the front, but the back will need something smaller. I am unwilling to drop the bottom bracket by running 650B+, so I am waiting until someone comes out with something in a true 2.5-2.6 inch width (on something like a P35).
Sweet. Thanks for the measurements. Another piece for me is that I'd like just one wheel/tire size to enable only carrying one spare on an international trip.
Alive and Well
Reply #8 on: January 22, 2015, 06:14:38 PM
« Reply #8 on: January 22, 2015, 06:14:38 PM » |
Just an FYI, I just remeasured, and I got 78mm in the rear. So a 2.6 in tire would be great, in my opinion. That leaves nearly a quarter inch on each side clearance. I have about 1" clearance on both of the bridges with 2.4" (true 2.1-2.2") continental mountain kings, so a 2.6" tire would leave around 0.5" clearance at the bridges. About the minimum I would want to run, unless I knew there was going to be bad, sticky mud.
Reply #9 on: January 22, 2015, 06:34:43 PM
Shilman
« Reply #9 on: January 22, 2015, 06:34:43 PM » |
Just an FYI, I just remeasured, and I got 78mm in the rear. So a 2.6 in tire would be great, in my opinion. That leaves nearly a quarter inch on each side clearance. I have about 1" clearance on both of the bridges with 2.4" (true 2.1-2.2") continental mountain kings, so a 2.6" tire would leave around 0.5" clearance at the bridges. About the minimum I would want to run, unless I knew there was going to be bad, sticky mud. One thing you might want to consider is front dérailleur clearance.. with my 2.4 racing Ralph's there is just a few millimeters if that.. it's the absolute max I could go..
Reply #10 on: January 22, 2015, 08:02:52 PM
Michael_S
« Reply #10 on: January 22, 2015, 08:02:52 PM » |
the issue with the Fargo is that it has a lower BB height than most 29ers to start with, so dropping it another 6-8mm using the 650B+ wheels is problematic. With regular 29ers the drop is less of an issue. I'm converting my custom 29er to 650B+ but I will have about 95 mm at both stays so I can run full 3" tires
mike
Reply #11 on: January 22, 2015, 09:17:09 PM
« Reply #11 on: January 22, 2015, 09:17:09 PM » |
mike
Thanks for the take Mike. I agree. It's one of my big concerns, and why I wondered about the about article, and other's experience with it. A lower BB would nearly negate the benefit of wide tires with pedal strikes, etc. on the terrain a 3" tire would help on. hmmm... pity to have to buy a new bike just to run 3" tires... but I guess thats why the Krampus and ECR are popular.
Alive and Well
Reply #12 on: January 23, 2015, 06:36:44 AM
« Reply #12 on: January 23, 2015, 06:36:44 AM » |
mike
I totally agree. All the numbers I am throwing out there (2.6 inches and associated clearances) are for a 29er rim and tire. So, this would raise the bike, which is a positive in My book.
Reply #13 on: January 24, 2015, 02:46:21 PM
squirrel
« Reply #13 on: January 24, 2015, 02:46:21 PM » |
Noob here, sorry to pipe in, but I have the same question as to wether the wtb trailblazers will fit in my Kona Explosif (27.5") frame? I measured just over 3" between the stays. I'm convinced I want to turn this bike into a pack mule Thanks
Since I want to use the new wtb scraper i45 rim, perhaps if that tire won't work, I should be asking if running a 2.4" tire will work ok on that rim?
« Last Edit: January 24, 2015, 02:56:56 PM by squirrel »
Reply #14 on: February 09, 2015, 04:54:30 PM
geekonabike
« Reply #14 on: February 09, 2015, 04:54:30 PM » |
Another b+ tire option 3.25. http://goo.gl/jZTEw3
