Found these two pumps when I was going through the dealer site at Specialized. Looks like it'll reduce weight and space by combining two pumps into one.
The dual-duty Windpipe Shock fills big tires fast and doubles as a high-pressure precision shock pump.
Thread-on Schrader head with Presta adapter
From fast inflation mode to high-pressure mode (up to 220psi) in one twist
Swivel hose for easy access to tires or shocks
Durable aluminum barrel
Glueless patches included in handle
Includes mounting bracket
This is the 2010 version that is not yet released.
Here's the 2009 version that is available right now.
Ergonomic T-handle also works as a tire lever and holds an emergency glueless patch kit
