  Topic Name: Water Filter/Purifier on: May 18, 2010, 02:03:58 PM
rhino
32xYM
« on: May 18, 2010, 02:03:58 PM »
Rhino here.  New to bikepacking, not new to bikes or backpacks, so thanks for entertaining my (many) questions in advance.
Question #1
What water filters/purifier does everyone recommend (primarily Arizona use)?
On most of the AZ bikepacking routes is an actual filter needed, assuming you carry 150-200oz of fluid?
I have an older MSR ceramic filter.  It can filter water out of mud, but the thing weights a ton.  I carry the emergency aqua tabs, but have never used them to date.
thanks
-rhino
  Topic Name: Water Filter/Purifier Reply #1 on: May 18, 2010, 02:15:47 PM
« Reply #1 on: May 18, 2010, 02:15:47 PM »
PUR Hiker or tablets, depending on the availability of water. I have had the PUR Hiker since my backpacking days and love it.
  Topic Name: Water Filter/Purifier Reply #2 on: May 18, 2010, 02:18:34 PM
rhino
32xYM
« Reply #2 on: May 18, 2010, 02:18:34 PM »
do you use the tabs as emergency only or do you rely on them when you "know" you will need to filter water?
  Topic Name: Water Filter/Purifier Reply #3 on: May 19, 2010, 09:09:51 AM
DiDaDunlop
« Reply #3 on: May 19, 2010, 09:09:51 AM »
I recently came across this:
http://www.sodis.ch/methode/index_EN
You can get clear water with using a shirt as a filter. And then carry a pet bottle on the outside of your backpack or anywere else. Filtration while on the go.
I dunno if it works with the water sloshing about during the ride and you need to have a solid system of changing bottles and keeping tabs on clean and dirty water.
