Topic Name: What tire preasure to run ???
on: April 06, 2012, 04:19:37 AM
Cheyou
« on: April 06, 2012, 04:19:37 AM » |
How low do you go ? Going with ghetto tubless and am 175 lbs.
Thanks Thom
Old ht 26er with not so good stuff bolted to it . Cheep and durable. And oh what fun to ride .
Reply #1 on: April 06, 2012, 12:09:03 PM
offroute
« Reply #1 on: April 06, 2012, 12:09:03 PM » |
40 psi tubeless for most; a bit lower on rougher surface. I weigh 165.
Reply #2 on: April 06, 2012, 01:45:00 PM
mbeardsl
« Reply #2 on: April 06, 2012, 01:45:00 PM » |
I think it depends a lot on the tire you are using also.
I generally run ~25psi tubes or tubeless and am 220-230lbs. But with one set of tires, anything over 22psi is way bouncy. Just depends.
Reply #3 on: April 06, 2012, 06:57:19 PM
« Reply #3 on: April 06, 2012, 06:57:19 PM » |
Is that your weight with full gear? What's your riding style: Ripping corners, popping the lips of jumps etc needs more air. Smooth and slower riding can have less. Also consider the tire: bigger diameter tires, tighter beads and stiffer casings can be run lower, skinnier, suple and loose fitting tires need more air.
Try it and see. Do short laps with 2 psi less every lap. 36 psi rear/32 front might be a good starting point.
I run 24-28 in my front tire and 26-30 psi rear for non bikepacking summer use. 170lbs+ person. 2.2 x 29" tires. Relaxed riding.
Reply #4 on: April 06, 2012, 09:25:22 PM
Flounder
« Reply #4 on: April 06, 2012, 09:25:22 PM » |
So much depends on terrain, riding style, tire choice, the amount of gear you tote. Kinda the same formula you use for regular non-bikepack riding.
Reply #5 on: April 07, 2012, 08:03:02 AM
raybum
« Reply #5 on: April 07, 2012, 08:03:02 AM » |
I ride 26psi F&R but then with BP gear, I up both to 30-32psi. I also increase the pressure in my reba front shock. Works well. btw, I ride a rampage on front, and a michelin racer on back, both on stans arches. (29").
Reply #6 on: April 07, 2012, 12:08:07 PM
Cheyou
« Reply #6 on: April 07, 2012, 12:08:07 PM » |
Maxxes ridgelines 26 x 2.1 alex DM18 total weight 225 great divide trail easy rider
Thanks Thom
Reply #7 on: April 16, 2012, 12:02:47 PM
« Reply #7 on: April 16, 2012, 12:02:47 PM » |
What pressures have you tried? If none, maybe 33-38 is a good starting point. Then start dropping.
Reply #8 on: April 16, 2012, 04:41:05 PM
Cheyou
« Reply #8 on: April 16, 2012, 04:41:05 PM » |
Thanks all . I got like 45 days till I start my ride . The Stan's is on the way . Ghetto tubless with fresh tires this weekend. Did a major overall of the bike last weekend . Still need maps and turn on the Spot tracker and Gore- Tex sox . Can I use the bear pepper spray as a spice !!! :0)
Thom
