  Topic Name: Wheel Build on: July 24, 2010, 10:36:24 PM
seanstokley
« on: July 24, 2010, 10:36:24 PM »
Needing to build a wheelset for my current project that is in the making. Not looking for all the bling bling fancy dancy stuff just a solid functional durable set of wheels. I'd like to go with disc brakes adn the 29r rim size. Is there a big difference between building with a 32 vs 36 spoke count? Obviously I'll be using this bike in a variety of venues and my 210lbs is not the over the top agro aggressive riding style either. Can anybody give me some info on some reasonably priced hubs and rims to go with and maybe share your impressions. Thanks.....
sean
  Topic Name: Wheel Build Reply #1 on: July 25, 2010, 07:05:33 AM
1speed
« Reply #1 on: July 25, 2010, 07:05:33 AM »
I've been building my own wheels for several years now because I was trashing everything I rode. I'm 225lbs and I've seen no need so far to go to 36 spokes. On my XC disc 29er wheels I have been running DT Supercomp triple butted spokes and alloy nipples, 32 spoke, 3 cross, with no issues, even on a single speed. I also use this combination on my no-brake/fixed gear bike that is using Velocity Blunt MTB rims and cyclocross tires on track hubs. The fixed gear sees a lot of rough dirt road riding and the wheels are holding up fine. I also build a lot of BMX wheels 32/3 and have not had a single wheel come back for truing. If you are going to be running front and rear racks and loading it to the hit for an "Around the World" trip you may want to move up to 36/3 cross or even 36/4 cross, but with modern metallurgy being what it is, 32/3 wheels are incredibly strong if built right with quality components.
I'm starting my first bikepacking/touring bike project myself and will be using Hope Pro2 hubs with the steel freehub body upgrade, Velocity P-35 rims, DT Competition double butted spokes and brass nipples, 32 spoke, 3cross. These are not cheap components but Hope hubs, Velocity rims with DT spokes have proven to be bulletproof for me. I just built this exact same wheelset for Scott Brady of Overland Journal/Expedition Portal for his adventure bike project. http://www.expeditionportal.com/forum/showthread.php?t=44361
« Last Edit: July 25, 2010, 08:16:36 AM by 1speed » Logged
  Topic Name: Wheel Build Reply #2 on: July 27, 2010, 04:00:26 PM
atom29
« Reply #2 on: July 27, 2010, 04:00:26 PM »
Salsa Delgado Cross rims are amazingly strong. Cheap too, relatively speaking. I've had good luck with Velocity Dyad rims also. For hubs, Shimano XT or Velocity sealed bearing hubs are reliable.
The 32 or 36 spoke wheels will build up the same if you're using a standard lacing pattern like 3 cross. You can get Velocity rims in 40 and 48 spoke too. To do a proper 4 cross, you would need a rim with angled spoke holes. The spoke angles get too sharp at the rim and stress the nipples otherwise.
« Last Edit: July 27, 2010, 04:08:01 PM by atom29 » Logged
