Pages: 1 [2]
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #20 on: April 02, 2012, 10:51:10 PM
phil_rad
« Reply #20 on: April 02, 2012, 10:51:10 PM »
I have been using the Geax Saguaros for a few years now on gravel, dirt and paved roads. They roll as good or better than a racing ralph and have more traction, I ride single speed so I'm sensitive to good traction and bad traction on tires.  They wear like iron; mine right now have about 2800 miles on them. No flats, sidewall tears. I run mine tubeless on Stan's Arch rims. I also have been using the AKA on my race bike, they too are good but don't last as long as the Saguaros.
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #21 on: June 22, 2015, 03:28:03 AM
sjstwrt
« Reply #21 on: June 22, 2015, 03:28:03 AM »
schwalbe super motos! theyre pretty slick but unless I'm full on trail riding they do wonders on gravel roads
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #22 on: June 22, 2015, 05:04:46 AM
« Reply #22 on: June 22, 2015, 05:04:46 AM »
I've been researching tyres to use on my Fargo for just the kind of mixed surfaces the OP mentioned.
The Kenda Kosmik Pro Lite II looks to have a fast rolling centre block, low side knobs for edge grip, are tubeless ready and in 29x2.0" have a reasonable volume.
Also in 2.0" are Stan's Crow and Raven. And tubeless ready.
A little narrower but looking like a fast roller is the 42 mm Soma Cazadero.
Narrower again at 40mm is the Clement X'Plor MSO.
Getting too narrow perhaps, the Challenge Gravel Grinder at 38mm.
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #23 on: June 24, 2015, 03:18:02 AM
Sparkyga
« Reply #23 on: June 24, 2015, 03:18:02 AM »
Personal favourite of all times was Racing Ralph but they tend not to live very long. I liked it as it was a solid "good" across the board tire. Now trying out a an Maxxis Ardent 2.4 EXO, very stable and fantastic traction on most surfaces but painfully slow on pavement, almost enough to make me cry...
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #24 on: June 24, 2015, 06:09:46 PM
Smithhammer
« Reply #24 on: June 24, 2015, 06:09:46 PM »
Just ordered a pair of Maxxis Crossmarks 29" x 2.1. Looking forward to giving them a good workout on some trips this summer.  thumbsup
- Benny Hill
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #25 on: June 27, 2015, 07:21:20 AM
csm
« Reply #25 on: June 27, 2015, 07:21:20 AM »
I've had the clement MSO X'plorer on my Fargo for about a year now. Didn't ride much over the winter so figure more like 6 months of actual riding. They're a great all-around choice. Much faster on pavement and most double track. Not great for single track but still fun. I've got a second set just in case they decide to stop making them.
Sent from my iPad using Tapatalk HD
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #26 on: June 28, 2015, 08:23:40 PM
redtabby
« Reply #26 on: June 28, 2015, 08:23:40 PM »
Just curious if you are running tubeless and at what pressures?  On my (lighter) aluminum 29HT I was running a 2.2 nano front and back.  On a new steel El Mar, I have Ardent 2.4 EXO front and back.   All on stan's flow rims, running about 20 up front and 25-28 out back.
The improvement in traction on fire roads and trails w/the 2.4 ardents is quite noticeable.  They are also maybe 20-25% heavier.
The El Mar with the 2.4s seems to roll really well compared to the lighter bike with demonstrated fast rolling nanos.  Maybe a hair slower, but nowhere near the drag I have with Purgatory/Captain Control front-to-back on a full suspension bike for trail use.
For my application, the trade-off is worth it to me - and I am thinking of trying to get 2.4s onto the aluminum bike when it is time to re-tire.  The ride with the big 2.4 in back at 25psi is quite pleasing.
One thing I discovered is that there is now a tubeless-ready 2.4 EXO 29 Ardent in addition to the standard one, which seems to be dual-compound.   I have that one on front, and a standard on rear.  A lot of my rides have paved segments between home and mountains, so I will see how long they last.
I will say that there is absolutely no comparison in terms of comfort and handling between tubed tires and typical pressures and what I've come to run now.
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #27 on: June 28, 2015, 09:05:33 PM
« Reply #27 on: June 28, 2015, 09:05:33 PM »
Maxxis Ikon's 3C EXO TR 2.4". My choice for mixed 'touring'.
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #28 on: June 28, 2015, 10:50:13 PM
JRA
« Reply #28 on: June 28, 2015, 10:50:13 PM »
Conti Race Kings 2.2"
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #29 on: June 29, 2015, 05:17:10 AM
Wayne
« Reply #29 on: June 29, 2015, 05:17:10 AM »
I recently installed the same tires. I'm curious to know what your rider+bike weight is and what pressures you are running front/rear. The only other example I can find online is Guitar Ted's review of the 40mm MSO tires. He said that he weighs 235 pounds and that 40 front & 45 rear worked for him. I'm only 145 pounds & the bike is 26 pounds dry. I am currently riding with 30 front & 35 rear. Curious to know if I'm in the right ballpark with my tire pressure.
Thanks for your help.
ps: Are you running tubes or tubeless??
Wayne
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #30 on: July 28, 2015, 08:41:23 PM
csm
« Reply #30 on: July 28, 2015, 08:41:23 PM »
I'm around 195 with a 30# Fargo before gear. Not sure what pressure I've been running... Harder on the road, softer off. Will check next time I think of it.
  Topic Name: Your favorite tire for pavement, dirt and gravel roads Reply #31 on: July 28, 2015, 08:41:38 PM
csm
« Reply #31 on: July 28, 2015, 08:41:38 PM »
Oh and I'm running tubes.
  Pages: 1 [2]
