  Topic Name: Mount Sinewave Beacon to aerobar extension? on: February 19, 2019, 03:02:06 PM
The_Mickstar
« on: February 19, 2019, 03:02:06 PM »
Does anyone have a slick way to mount a Sinewave Beacon (which has a common 10mm tab) to a standard 22.2mm aerobar extension?
I'm trying to avoid having to use a "nob" and a standard handlebar mount, but that may be my best option.
  Topic Name: Mount Sinewave Beacon to aerobar extension? Reply #1 on: February 20, 2019, 08:40:38 AM
« Reply #1 on: February 20, 2019, 08:40:38 AM »
You could buy an aerobar gopro mount. Then use a gopro to 10mm tab adapter. I think sinewave makes an adapter for that as do several other companies. I have one of these garmin/gopro mounts attached to my handelbars that works great.
  Topic Name: Mount Sinewave Beacon to aerobar extension? Reply #2 on: February 28, 2019, 01:26:59 PM
Brian McEntire
« Reply #2 on: February 28, 2019, 01:26:59 PM »
Kevin B does fantastic work and is very reasonably priced. I am using his GoPro handlebar mount which he machined to use with the 10mm tab on my Beacon, but he makes other pieces that might work for you.
http://www.pacifier.com/~kevinb/GoPro_Mounts.html
