I just went though this process with my local outfitter, for AK in Jan/Feb.
I was thinking the same, going with a big bag, but we worked with some of the gear I already had, to finish with a really cool modular system.
System:
OR Alpine bivy
Mont Helium 450
Mont bell spiral down hugger
Mtn Hardwear synth puff pants
Mtn Designs 700 hooded down puff jacket
tech fleece
icebreaker GT 200 base
Exped synmat UL7
Z lite pad
The only thing I needed to buy for this was the Helium bag, had everything else. Ended up with a very packable, modular system, amazed how compact the helium was when packed!
This gave me a main bag I can use around here (instead of only OS when it is in double negatives) so far more versatile in the long term, but YMMV. Double use then of the puff when stopping for meals/water and system redundancy in case of single component failure (water contamination). Admit it does take more time to setup - as opposed to a single bag system like the Exped waterbloc 1200 which I also liked, but I aint made of money - so modular suits me fine.
Wow sounds like a great winter warmth system. Any picts ? I know you are still waiting on 1 piece to complete the system.
stumpyfsr,
Something I always do with new gear is to test it some place where I can bail if things don't work out.
Backyard testing will also help you tweak the system to your liking and give you confidence in it.
Here's a pict of a snow load failure from my backyard. I was testing a new winter tarp before hitting the woods.
Turns out tarp pullouts and 6" on new snow overnight did not work well. The side pullouts prevented the snow
from sliding off. Thank goodness I had the tarp ridgeline on sliding prussic knots or something would broke or torn.
So I guess what I'm suggesting is watch the weather and give your new sleep system a few test runs in the backyard.
hth
