Home
Forums
Routes
Gear Reviews
How to contribute
Personal setups
Trip reports
Ultra records
Help
Search
Login
Register
Bikepacking.net forums
Forums
Winter bikepacking
Winter lube
Pages: [
1
Topic Name: Winter lube
on: December 20, 2010, 11:52:50 AM
Winter lube
on:
December 20, 2010, 11:52:50 AM »
Getting mixed info from my lbs on lube for the snow bike. What are folks using for chain, bb, cassette, etc.? Locally I won't be out much below 0°F riding. Colder overnight.
www.littlecirclesvt.com
Reply #1
on: December 24, 2010, 11:55:47 AM
Damnitman
Re: Winter lube
Reply #1 on:
December 24, 2010, 11:55:47 AM »
Trend setting Alaskan LBS is using "viper lube". No experience with it, but Speedway would probably hve it figured out...Another option is an offering from some NASA guy called "morningstar soup" stays incredibly usable below -40f, even after being "cold-soaked" for a week...though some have had mixed long term results...reportedly issues with internal corrosion, thus the switch to "viper lube"...I hose my cassette, chain and der's down with aerosol "rem lube", a very light silicone disolved in a very light carrier, works great for a couple rides before I need to reapply, though totally not suitable for any other applications, except maybe to lube cables / housing...contact Speedway cycles in Anchorage AK for info on Viper Lube, or google it...I'm also experimenting with a "For Aircraft use only" product I found at work...looks promising...
Reply #2
on: December 17, 2012, 06:25:22 PM
jaustin
Re: Winter lube
Reply #2 on:
December 17, 2012, 06:25:22 PM »
when I lived in Fairbanks, AK they recommended Lubriplate Mag-1 grease. I think it was made for equipment working on the oil pipeline and is good to very low temps. I've personally used it to -40 in my freehub body and it worked fine.
Pages: [
1
Please select a destination:
Site
=> Site issues / Suggestions
Forums
=> Bikepacking
=> Question and Answer
=> Routes
=> Ultra Racing
=> Winter bikepacking
=> Classifieds
Powered by SMF 1.1.21
SMF © 2015, Simple Machines
Loading...
