Hydration » Pneumo Dry Sack by Pacific Outdoor Equipment
Pneumo LTW Dry Sack
Our great backpacking dry bags just got better with the introduction of the Pneumo LTW. We kept all the features of our benchmark Pneumo dry bags; welded construction, roll top closure, compression purge/fill valve, and added weight savings with the introduction of a new 40Dx30D ripstop fabric and a refined closure. We shaved a full 1.5 oz out of the 15L size alone! 5 sizes to fit whatever you may be packing. |
September 26th, 2008 in
Hydration
I have been using the 5L bag for about three years with no issues. The great part of this bag is the compression purge/fill valve. After putting your equipment in the bag and rolling and closing the top of the bag you can purge the trapped air from the bag. You can also use the same valve to fill the bag with air to make a pillow or PFD for your equipment. There are two points at the bottom of the bag that can be use to lash the bag to your pack of other gear.
Good bags,
used the 25 L for years before a bear destroyed it. The 50 L is also good, but the 65L is a bit on the wide side.
my only gripe is the corner lash points – they can easily tear out if you run webbing through them, use min-biners and no problem though.
I have taken these bags on over 100 wildfires and they’re still going strong. Love that they keep my gear compressed and dry and when partially inflated make great pillows!
