Sleeping Pads » NeoAir pads by Therm-a-Rest
 NeoAir
AVAILABLE APRIL 2009: The NeoAir mattress represents the world’s most advanced engineering in ultralight comfort. Beyond being the lightest air mattress available, we’ve utilized two patent-pending internal technologies, making it up to three times warmer and far more stable than any other uninsulated air mattress available. And when it comes to space in your pack, you’ll appreciate that it’s no bigger than a one-liter water bottle. Revolutionary by design, the gossamer NeoAir mattress makes comfort one less thing you’ll need to compromise when traveling Fast & Light.
Ultralight & Compact: Weighs just 14oz. and packs down to the size of a 1-liter water bottle. |
Unrivaled Warmth: Our patent-pending reflective barrier returns warmth to your body and reduces heat loss to the ground, keeping you three times warmer than any other uninsulated air mattress |
Sleep Stable: When inflated, patent-pending Triangular Core Matrix technology creates an internal truss system, resulting in the most stable non-self-inflating air mattresses. |
Lasting Performance: Achieving thermal efficiency without down or fiber insulation means the NeoAir can be inflated directly without the added weight of a pump, or worrying about exhaled moisture wetting insulation and decreasing performance. |
Large |
Regular |
Medium |
Small |
Weight |
1 lbs 3 oz/550 g |
14 oz/410 g |
13 oz/370 g |
9 oz/260 g |
Rolled Size |
11 x 4.5 in/28 x 11 cm |
9 x 4.0 in/23 x 10 cm |
9 x 3.3 in/23 x 9 cm |
R-Value |
2.5 |
2.5 |
2.5 |
2.5 |
Thickness |
2.5 in/6.3 cm |
2.5 in/6.3 cm |
2.5 in/6.3 cm |
2.5 in/6.3 cm |
Suggested
Price (U.S.) |
$169.95 |
$149.95 |
$139.95 |
$119.95 |
(39 votes, average: 3.64 out of 5)
Loading ...
March 6th, 2009 in
Sleeping Pads
Have used the Neoair now on three overnights in the northern Colorado mts. Has kept me warm and comfortable in rainy 40 degree temps. It is a big advantage in comfort over a closed cell pad or a thermarest and much lighter that other air matresses. I am 6 ft but use the small size to save on weight and bulk (using my pack for my feet and lower legs) Put it in tiny stuff sack a Sierra Design rain shell comes in and save $15
i just finished up a stint with the size small of this pad racing tour divide. i must say i was quite pleased. i expected it to be more fragile than it is. no puntures or slow leaks. it is narrow but surface begets no slip issues so width is less of a factor, particularly if you drop the pressure appropriately on it (think tubeless tires). for multi-day ultra racing, i would not use anything else. uber compact! thanks thermarest.
